new fluids in used car?
As for trans fluid, not sure what the M6 people like to use. The T56 trans is not my specialty. I'm a 4L60E type of guy.
Rear end fluid; since you have a 2000 I'd use a 75W90 synthetic fluid and throw in the GM additive as directed by the GM service manual.
Coolant; stick with Dexcool, and get the system flushed since it's probably been in there for the last 6 years. What I do is to drain and refill mine every spring, but that only replaces about half the coolant (I get about 1.5 gallons out of the 3+ gallon system). I think that's plenty so long as you're doing it every year, but after 6 years and 50K miles I'd say to fully flush it at least for the first time.
I use Mobli 1 5W30, Dexcool, Rear end is Royal purple w/ Gm additive. I did not change power steering or brake fluid.
I use Mobil 1 5w-30, dexcool with additive (similar to water wetter), standard ATF in the T56 and JT-7 non-synthetic in the rear diff. If you take your car up to Walker's, he has a coolant flushing machine he can hook up to your car to remove the old fluid, clean the system and add new fluid. It's a lot neater than pulling the block plugs, but it will run you about $70.
Dunno 'bout the M6 too much.
Oil change, differential oil change, flush/refill
coolant goes without argument.
I'm not **** about frequent oil changes with
the Mobil 1 engine oil, but my 10 bolt and A4 I service
about every 25K miles. Still running stock A4
& 10 bolt (see sig)
For coolant, stick with Dexcool, no other choice.
I used Royal Purple syn for the rear, does not require additiive.
Now for the hard part, the oil. Personally, I like Mobil 1 5W-40, should use M1 anything -30, its too thin. Search through posts, make you own decision.
Good luck with the car, you will love it.
I had put M1 synthetic ATF in my 00' M6 about 4K miles ago. The shifting was getting harder. I dumped the M1 and put in regular Dexron III and it shifts great again.
This place is kind of like "The Collective", we're here to help each other by sharing our knowledge.
