Sponsored by: CARiD
Is 0W-40 a suitable oil?
Old Jan 25, 2006 | 07:40 PM
Renegade's Avatar
I run Royal Purple 5W-30, and have never had any problems rain, shine, snow and all. But I agree that you should run the German Castrol, or one of the others mentioned. I've heard that M1 5w-30 is a thinner 5w-30, that is why I chose RP over it. Couldn't hurt to try it out for ahwhile, as long as you have oil, your car isn't going to blow up right away lol.
Old Jan 25, 2006 | 08:24 PM
GreekGator's Avatar
According to Patman, any of the 5 or 10 W 30's should be avoided. The GC or 5W40's are the best to get.
Old Jan 25, 2006 | 08:57 PM
TJ's Avatar
TJ
when is the Mobil 1 crew getting back on track?
Old Jan 25, 2006 | 09:03 PM
GreekGator's Avatar
Mobil 1 crew? I run M1, but the 5W40 is on hold for a little so i switched to the GC until then. I might try the Belgian Castrol(5W40) and see how it compares to the M1. Id like some input from others on this oil though.
Old Jan 25, 2006 | 09:13 PM
TJ's Avatar
TJ
Originally Posted by GreekGator
Mobil 1 crew?
the folks that produce the oil.
when will production continue, is there any confirmation?
Old Jan 26, 2006 | 06:01 AM
Patman's Avatar
As far as oil filters go, I highly recommend the K&N.
As far as the Beligian 5w40, I haven't seen any results in an LS1 just yet. Anyone here want to try it out and send the oil off for analysis at the end of the interval?
Old Jan 26, 2006 | 09:00 AM
jimmy 2 Times's Avatar
I'll be doing an oil/filter swap, if i can find the Belgian oil i will try it, and send it out.
where can i send the oil for analysis?
Old Jan 26, 2006 | 09:41 AM
JayLS1-327's Avatar
Thumbs up
Blackstone Labs
http://www.blackstone-labs.com/
Old Jan 26, 2006 | 11:03 AM
GreekGator's Avatar
i wouldnt mind trying it either. but youd have to about 6 months b/c i just changed my oil......
Old Jan 26, 2006 | 03:09 PM
Originally Posted by JayLS1-327
thanks, Now i will search for some belgian oil
Old Jan 26, 2006 | 10:26 PM
TJ's Avatar
TJ
autozone, and sometimes advance. advance usually has a special on the syn at 3.98 a quart, so check your papers and buy it there if you can.
Old Jan 29, 2006 | 12:49 AM
  #32
GreekGator's Avatar
yea, i saw it at Autozone the other day. Not sure if it was the kind that is made in Belgium though.....
Old Jan 29, 2006 | 09:33 AM
  #33
TJ's Avatar
TJ
"made in belgium" right on the back. you cant miss it.
good luck.
Old Jan 29, 2006 | 11:46 AM
  #34
GreekGator's Avatar
Thanks dude! I will go back to AZ and see if its the goood stuff.
Old Jan 30, 2006 | 09:32 PM
  #35
02LS1WS6's Avatar
patman...if i decide on goin with amsoil which setup do you suggest that i get and if i go with castrol which setup do you suggest?
