Is 0W-40 a suitable oil?
Anywho, i now have a really fast tap/knock in the engine, sounding different than the orginal piston slap, from just off idle to about 2K rpm where itll smooth out. The engine also seems to be running really rough when revved just off idle, before it smooths out around 2K and seems to be fine thereafter. The problem is most of my driving leaves me about that range when im cruising, so im living with a constant vibration. I figured maybe the oil just needed to be fully heated and the noise/vibes might go away, but it seems to persist even at full temps. Was the 0w simply too thin? Just a coincidence or my imagination? Any ideas? Its been in the car for about ~2000 miles and the motor has consumed about a quart of it. Should I switch back to 5w-30 and note if theres a change?
I also did the GM Top engine treatment just before switching to the new oil, so thats a variable as well. The engine didnt sputter a bit despite sucking up 2 bottles of the treatment, and no smoke after letting it soak for about 15 hours. Keep in mind this is the California variant of the treatment, since the chemicals in the normal GMTEC treatment arent allowed in Cali. Out here we get a small small bottle of the solution with a different blend to coincide with california law. I used two bottles of the treatment to get a similar volume compared to the treatment offered in the other states (Possible error of judgement on my part). Somewhere in the back of my mind im worried that the treatment did something funny internally.
i have used 5w-30 since i originally bought the car.....and i have noticed some oil consumption, do you think that if i switch to M1 0w-40 it will remedy some of that consumption? As far as i am reading, this may help it? Care to add some insight?
BTW, i tried to search on this, but I think that that feature is not working
ive run it, and the clatter is less than with 10w30 M1.
i have had the best luck keeping the valvetrain quiet with the M1 5w40 T&SUV
in oils for cold start up clatter (valve train only).
However, mine quiets up when warm.
I'm using M1 0W40.
Engine runs great, so good it scares me it's gonna quit.
