Sponsored by: CARiD
Washer fluid wont spray.
Old Jan 24, 2006 | 12:58 PM
Mike2kZ's Avatar
Default Washer fluid wont spray.
The window washing fluid wont spray anymore.. resevoir is full. Is it the motor/pump? if so, where is it and how do you replace it. Any help would be appreciated.
Old Jan 24, 2006 | 05:54 PM
Blown Ta's Avatar
the pump is mounted on the tank it self. check for power. 12v
if you need one let me know. i got one i can sell you.
Old Jan 24, 2006 | 09:18 PM
twort's Avatar
mine wouldn't spray either but the hose came off where it sprays on the windshield. it was still pumping just on the engine instead.
Old Jan 25, 2006 | 07:44 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Another thing is the little spray nozzles get plugged, especially if
you put (hard) water in the tank instead of washer fluid.
If that turns out to be the case, try spraying WD40 through both
sides of the nozzles.
