Sponsored by: CARiD
leaky 2000 SS - water on floor?
Old Feb 1, 2006 | 07:51 PM
who281's Avatar
Default LEAKY DRIVER FLOOR PANEL? 2000 camaro SS
i got my 2000 camaro SS about 2 months ago and realized that when it rains i get about a 4" by 4" square of water on my drivers carpet....i think there is a leak in my floor board...anny1 else had this problem?
Old Feb 1, 2006 | 07:58 PM
SSPerformance's Avatar
your window leaks or t-top where the meet
Old Feb 1, 2006 | 08:16 PM
WhiteKnightZ28's Avatar
Tech Resident
T-Tops... the bane of the f-body owner
Old Feb 1, 2006 | 08:30 PM
who281's Avatar
Default ??
i thought it was thhat at first to but its not on my floor mat its only underneath the matlike the top of my mat is dry but if i lift the mat up the floor itself is damp??
Old Feb 1, 2006 | 10:17 PM
who281's Avatar
Default leaky 2000 SS...?
why is the floor UNDERNEATH my floor mat wet? any1 else hae this prob?
Old Feb 1, 2006 | 11:14 PM
Swang's Avatar
From: Hometown:Mount Carmel, IL Current: Las Vegas, NV
hmm...it did that on my passenger side but it was a/c related. dont see that being it this time of year. i hope someone posts up, ill at least take this too the top for ya.
Old Feb 1, 2006 | 11:24 PM
who281's Avatar
thanks alot man hopefully i can figure this **** out.......
Old Feb 1, 2006 | 11:26 PM
98TwoToneSS's Avatar
i depends on what side it is on
Old Feb 2, 2006 | 01:11 AM
99SSHawaii's Avatar
Open your hatch, and check for body panel seperation in the corners of the drain ducts, a few hard launches can open cracks in the body which lead to water seepage during rain.
Old Feb 2, 2006 | 09:34 AM
zoomer02's Avatar
Check your A/C drain. There is a little rubber tube, behind the inside of the passenger front tire, that is supposed to drip condensation from the evaporator core. This is probably clogged up and when it rains, it fills up when water runs off of the windshield and then it drains down the heater vent on the floor. This will run down the back of the carpet and puddle up on the passenger side floor. I had this happen to two other older GM cars that I owned. Good Luck.
Old Feb 2, 2006 | 11:16 AM
Low N Slow's Avatar
Check the grommet for your hood release cable where it goes thru the firewall, mine had popped out and I had the same water under the mat you do.
Old Feb 2, 2006 | 04:47 PM
who281's Avatar
Default still confused on my leak
well i thought my 2000 SS was leaking in rain but it seems that it gets water on the DRIVERS side floor underneath the floor mat whenever my A/C or my heater is on? wtf is going on
Old Feb 2, 2006 | 05:01 PM
01sunsetSS's Avatar
hole in your firewall? I have no idea just throwin that out there
Old Feb 3, 2006 | 06:36 AM
svtwhat?'s Avatar
heater core?
Old Feb 8, 2006 | 04:00 PM
Cyborg's Avatar
Do you find this from the engine side or cabin side?
Old Feb 8, 2006 | 04:03 PM
Cyborg's Avatar
So check the corners where the b piller meets the quarter? Is that where the drains are?
Old Mar 31, 2006 | 03:33 PM
ins0mnia24's Avatar
My 02 z28 Just started doing the same thing this week and funny thing is it hasn't rained in more than a week
But i have the same exact thing going on in my car Driver's side floor but only wet under the floor mat about 3 inches in front of my Driver's side seat and around a 3x5 inch wet spot and not one trace of dampness or water anywhere near the fire wall
Did you find out where it's coming from yet?
Saturday i am going to pull the driver's side seat out and all the trim and see if i can trace it under the carpet
Old Mar 31, 2006 | 03:38 PM
1REDHEAD's Avatar
Had that problem once and come to find out the car had been wrecked before and the frame warped. Later on (when I was the owner of course) I started getting lots of water under the mat. It would soak the floor. Never anywhere else, just under the drivers side. The smell from the water and sun will run you out of the damn car in the summer. Best thing I did was pay to have the car professionally clean the floors and seats and sell it. Of course you may can find the source of your trouble and take care of it yourself. I didn't have that luck.
Old Mar 31, 2006 | 04:49 PM
who281's Avatar
i havent found out my prob yet... but ins0mnia ur prob sounds exactly like mine...if u find the prob pleasee let me know....
Old Mar 31, 2006 | 04:59 PM
MTN_Z's Avatar
Typically, if you aren't leaking from the window/T-Top area, it's somewhere from the back hatch. Not too long ago, we had alot of rain here. I had some papers on the driver's side rear floor mat and they were soaked. I haven't checked mine out yet, but like some people were saying above there are seams in the hatch area that separate or the weatherstripping in the hatch area isn't doing it's job right. The water will start draining down into the car and then water gets trapped under the back seat. Afterwards, as you stop and go, water starts moving towards the front into your car. This might not be your problem, but check the carpet behind your seat. If it's wet, pull the back seat out because there might be a nasty *** puddle underneath it and the water has been making it's way to the driver mat. Otherwise, take a look underneath your car and see if there is anything suspicious.
