Sponsored by: CARiD
Car tried starting itself
Old Feb 3, 2006 | 12:13 PM
gettinthere's Avatar
Default Car tried starting itself
Mods, if this is in the wrong forum please move it to the right one.
This is gonna sound wierd, so I'll try to explain it as best as possible.
This morning at about 6:00 I thought I heard my alarm (panic button) going off. At first I thought someone may be trying to steal my car, but then I remembered that b/c of where I parked on the driveway it was blocked in by 3 cars. Then I didn't hear it anymore and fell back asleep. A few minutes later my dad woke me up and said that my car was trying to start. I had both sets of keys on my nightstand.
So I go downstairs and sure enough, the panic alarm is going off and my starter keep trying to crank the motor. It's try for about 5 seconds and then stop for a few more seconds. Then try again. And each time the panic alarm would go off. I got in the car and there were no keys (I still had both) and the ignition was off. So then I started it up and shut it down. Everything seemed to stop. but just to be safe I desconnected the battery and the trottle cable. And no I don't have a remote start.
Has anyone ever heard of this? And if so, what is causing it?
It was also raining a bit if that matters. And I just finished an M6 -> A4 swap last week, but I don't see how that would have had anything to do with it seeing as how it's been a week and this is the first time it's done it.
Can anyone help?
cliff notes - Car tried starting itself with no keys
Old Feb 3, 2006 | 12:42 PM
ss1129's Avatar
Ever seen Christine?
Old Feb 3, 2006 | 12:49 PM
4bangermustang's Avatar
ROFL!!
Old Feb 3, 2006 | 12:54 PM
NBM2001z28's Avatar
Restricted User
You should take it back to Tony and have him look at it, I'd imagine it was something with the swap.
Old Feb 3, 2006 | 01:00 PM
LSWon00's Avatar
Check the ignition wires, if the wires have melted they can make contact and the car will try to start itself, so yes I have seen this.
Old Feb 3, 2006 | 01:19 PM
I'm thinking it might be a combo of a bad battery and the starter remote wire touching something.
Old Feb 3, 2006 | 01:23 PM
You're not the first person to ask that.
Old Feb 3, 2006 | 01:29 PM
baddogz28's Avatar
It's possessed.
Old Feb 3, 2006 | 02:20 PM
Rescue Ranger's Avatar
Man thats le scary. my immediate thought seeing the title was remote starter issue, we had a neon in town that had the clutch bypass fail and it rammed itself into the wall...
I would definately say some wires are where they aren't supposed to be, but saying that warrants your response to be along the lines of 'yea dude, no sh*t.'
Good luck.
Old Feb 3, 2006 | 02:26 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
WTF? haha that is kinda cool/scary.
Old Feb 3, 2006 | 02:47 PM
King James's Avatar
If you know Brian and the scary **** that has gone on in his house this is even more scary
Old Feb 3, 2006 | 04:34 PM
A few of the LS2 guys did suggest the ghosts.
But I replaced the battery with an Optima red top about 45 minutes ago and nothing has happened. Before with the dying battery if I hooked it back up, it'd kick on the starter in about 5 seconds. But I am still going to do the safe thing and chase down some wires.
Old Feb 3, 2006 | 04:47 PM
redbandit98's Avatar
dont worry about it man..its normal for some of those to do that..i have a chevy truck that does the same thing..some remote start systems will try to restart everytime they loose power and then get it again..for instance in your case of a battery..im guessing that your battery would run all the way down from sitting or whatever, as soon as you hooked up the charger or jumper cables ..its turned over, and im betting that if it didnt start , it tried to start 2 more times before giving up..thats why your supposed to put the warning about the car having a remote start becuase about 1 out of 10 do it. I dont know why, prolly a bad diode or something somewhere but none the less, ive seen many of these that do the exact same thing..you dont have a problem, you just have a picky one that will try to start each and everytime you disconnect and reconnect the battery..a solution is to pull the ign fuse until your ready to start it..or make sure you have your key fob ready so as soon as you hear the fuel pump kick on like its going to start you can disarm it
matt
