Sponsored by: CARiD
Air Bag Light!!!
Old Mar 23, 2006 | 11:41 AM
Derek_02's Avatar
Ok thanks guys. Im gonna try and hook the scan tool up to it again tonight. Just for reference i just put the car back on the road last week and drove mabey 3 times so far (the weather got shitty up here again). So thats mabey a total 10 times the car has been turned on and off since the new cluster was put in. Dont know if that changes anything but Ill let you know how the scan tool works out. Thanks again.
Derek
Old Mar 23, 2006 | 12:11 PM
2002_Z28_Six_Speed's Avatar
Ok! I was just kind of wondering after a month. HEHE
Old Mar 23, 2006 | 04:43 PM
Derek_02's Avatar
ya no problem. haha
Derek
Old Mar 27, 2006 | 08:48 PM
WSSix's Avatar
If you want to know if it is because the new cluster isn't synchronized just stick the old cluster back in temporarily and start the car. I wouldn't be surprised if the air bag light goes out the first time you start the car.
Old Jul 4, 2006 | 06:01 PM
Michael Ozorowsky's Avatar
think I have this exact issue. How do I synchronize properly? Can it be done with HP Tuners?
Old Jul 4, 2006 | 10:19 PM
No a dealer can do it or if you do so many ignition cycles without throwing a code it will go off.
Old Jun 30, 2008 | 04:06 PM
topdj-com's Avatar
I know this is an old post but does it go away after so many cycles?
Old Jun 30, 2008 | 06:01 PM
Got the PM. Did you change ANYTHING else besides the cluster?
Old Jun 30, 2008 | 07:05 PM
topdj-com's Avatar
nope simply replaced the cluster I did not have any lights before that,
Old Jun 30, 2008 | 07:45 PM
topdj-com's Avatar
looks like it may not go away this is a cut paste from GM techline
With a scan tool, verify that the IPC is programmed with the correct VIN by comparing the VIN that is stored in the IPC to the VIN that is stored in the PCM.
Does the scan tool indicate that the IPC is programmed with the correct VIN?
Old Jun 30, 2008 | 08:46 PM
You can replace a IP from one car to another. It isn't plug and play though.
You have to turn the car on. Leave on for 30 min. Turn it off for 30 minutes. Cycle until it works. Eventually, the modules will relearn all the correct "tokens" to pass around.
This isn't documented in any literature I have seen. It was told to me by some people I know from GM. It worked for me, too.
A Tech 2 should still do that anyways.
I think that statement was calling for a Technician to check and see if stuff was stolen.
Old Jun 30, 2008 | 09:53 PM
  #32
topdj-com's Avatar
on like running? or just the key on run?
I did disconnect the battery for an hour didn't help
Old Jun 30, 2008 | 10:19 PM
  #33
Key on not running. That probably requires a garage and a battery charger but its worth a shot on a lazy afternoon. Unless that's not possible. then go for the Tech2. But that costs money...
Old Jul 1, 2008 | 08:02 AM
  #34
topdj-com's Avatar
oh ya, got's to have a garage I built this one with my friends 28 x 38
I have not sided it or finished the inside. But it does have 50amp service and gas heat Man has to have priority's.
http://www.performanceboats.net/images/garage1.jpg
Didn't know it was a OK to leave the ignition in run like that
Old Jul 1, 2008 | 08:20 PM
  #35
topdj-com's Avatar
I tried the 30+ min on and off a few times today didnt seem to affect the light,
I had a rolling 5.10,25,50/200 amp charger booster set on low charge to keep the battery alive
