Help Removing Center Console
If you ever wanted to add a new shifter or short stick, now would be the time as 90% of the work is getting the console off.
then there is a little staple looking thing on the front of the boot (facing the stereo) just put a screwdriver under it and pry it out gently, then just pull the boot off.
After that and the 2 screws below the change holder inside the console and a little bit of wigglin the top half should come right off, and then you should be able to see how to get the bottom off
