A few Problems
Also, When I get to and above 50 MPH in Drive, I feel alot of pressure in the exhaust then hear a backfire( when it gets under 50 mph) and it seems to go back to normal noise. In Overdrive, at or above 50 the car sounds alot quieter, seems lieka differnet noise. Maybe sputtering.
I have some gauges( came with the car). One is Air/FueL Ratio. It always show sthat Im burning lean but Im not sure how reliable it is as my RPM gauge works, then it will just say 00 RPM.
The exhaust is a good thing to look into if you are really lacking power. If you can see that the cat is obviously way too hot from under the car after starting you found the problem!
If you suspect that the previous guy did a bad tune on it (since a AFR gauge is installed) having it retuned might help you out. It looks like you have some mods in your sig.
