Sponsored by: CARiD
tire pressure
Old Feb 8, 2006 | 10:06 PM
delinquent543's Avatar
Default tire pressure
whats a good tire pressure for street tires? on the tire it says a max pressure or 44psi, but i talked to a guy who said thats way too much and about 30 is best. any thoughts?
Old Feb 8, 2006 | 10:10 PM
plus it says in the manual 38psi for any speeds over 100... any validity to this?
Old Feb 8, 2006 | 11:04 PM
2K2WS6TA's Avatar
I run mine @ 35 psi all round, if the manual says 38 psi for 100+, I'd be putting in 38psi
Old Feb 9, 2006 | 05:41 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
All my 4th gen F-bodies have listed 30psi as the recommended pressure for both front and rear. This info can be found on a sticker on the inside edge of the driver's door.
Old Feb 9, 2006 | 09:26 AM
jmm98LS1's Avatar
I run 34 in the fronts and 30 in the rears.
Old Feb 9, 2006 | 05:36 PM
davered00ss's Avatar
Moderator
Say's 30 psi on the inside of your drivers side door.
Old Feb 9, 2006 | 05:47 PM
2001NBMZ28's Avatar
30 PSI cold.
Old Feb 9, 2006 | 06:26 PM
thanks guys. what about the 38 psi for 100+ driving? i mean, the tire tends to rise and shape inward when moving, so wouldnt it make sense to have lower pressure? just a thought
Old Feb 11, 2006 | 01:24 AM
CamaroEMT's Avatar
I'm guessing you're running the stock or equivalent tire which says 44 psi max. In this case I'd run every bit of 38 psi giving yourself a good 6 psi of play in case you hit a big pothole or there is a drastic increase in temperature. As nwe all know from High School/College Chem the drastic influence of temperature upon a gases volume. I personally run 38 psi on my stock tires in the winter and 45 psi on my Eagle F1 GSD3's in the summer (they have a max of 51 psi). The handling at this config can't be beat. Tread wear is excellent. I personally like to run my tires high and have never had a problem as long as you give yourself a good 6 psi of play. Mess around with the setup and find something that works for you.
Old Feb 11, 2006 | 04:18 PM
BackinBlack02SS's Avatar
Do you have an f body or vette? I don't remember anything about 38 psi over 100 mph in my 02 Camaro manual.
Old Feb 11, 2006 | 07:27 PM
Pewterpower's Avatar
Neither do I.... and mine says 31psi COLD.
Any way, I run 38 up front and 31 in back.
Old Feb 11, 2006 | 07:32 PM
Super Speed's Avatar
You should personally run nitrous that way when someone asks you to race you can say
Are you sure? I have Nitrous
I recommend you do what the tire says I run mine at 30 when the max is 35 I think
Old Feb 11, 2006 | 09:45 PM
INMY01TA's Avatar
I've had two F bodies (01 and a third gen, 91) and both said keep them at 30psi cold. I ran 35 in front on the 3rd gen and 32 on the rear and rotated them every 7000 miles. This caused a bald stripe to be worn into the middle of the tires prematurely. I now keep them at 30psi like GM suggests.
Old Feb 14, 2006 | 07:11 PM
The reason I keep my fronts filled harder is cuz I live right by an Interstate exit on/off ramp that I use alot. So that is alot of driving in circles cuz it's the typical cloverleaf designed junction. I was getting the outside edges of my fronts worn off very quickly. But once I started running the fronts harder, like 38 psi, they started wearing more evenly.
