Sponsored by: CARiD
Power Steering Pump going?
Old Feb 12, 2006 | 12:14 PM
2002LS1Z's Avatar
Default Power Steering Pump going?
I have noticed lately that in the morning when my car is cold and I make sharp turns I get a noise when turning the wheel. It sounds like a faint grinding noise. This goes away after warmup. Also, I have notice when doing a u-turn it's starting to whine. My mileage is 52,000. If so what kind of cost am I looking at to fix this?
Old Feb 12, 2006 | 06:25 PM
Syxx613's Avatar
check ur fluid
Old Feb 14, 2006 | 08:57 PM
blackhawk J's Avatar
GM High Tech performance did an article on a high performance PS pump for LT1 and LS1 engines, I think it went for about $225, and with the associated pulley it gained 3 hp and worked better than the stock unit too!
Old Feb 14, 2006 | 09:13 PM
carado1984's Avatar
you can get a stock one used for about 50-100.. i found one with 20k on it and it worked fine.. there always on ebay, and if you find one with a cracked reservoir, since some are from wrecked cars, you can swap your reservoir onto it
