Sponsored by: CARiD
injector cleaner?
Old Feb 25, 2006 | 05:12 PM
shaun's Avatar
Question injector cleaner?
what is the best one to use????????????????????????????????????????????
i normaly use the lucas in the skinny bottle but the first time i put it in this car it was throwing a ses light that said bank 1 was runing lean [dont know if it was the reason though]
thanks
Old Feb 25, 2006 | 07:24 PM
GXPPOWER's Avatar
octane boost is the best cleaner i would think.
Old Feb 25, 2006 | 08:52 PM
YoMommasTA's Avatar
thanks
lucas can kill a used car,it cleans all the rust and crap quickly,you can guess what happens when rust gets into injectors.these cars are known for rusted fuel rails and fuel lines.i know of a few huge repair bills caused by using lucas in a used car.its great stuff when used from new but putting it in a used car without knowing the condition of the fuel line etc is playing with your wallet.i just read here on the forum someone with a 99 grand am stopped running after adding lucas,it loosened so much crud it jammed all the injectors.
Old Feb 25, 2006 | 09:29 PM
shaun's Avatar
Question reply to my post
so should i use any or leave it alone?
Old Feb 25, 2006 | 09:37 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
I use STP injector cleaner usually. Have also used LUCAS cleaner .....I also use LUCAS Oil Additive all the time...I doubt these cleaners would cause your problem....
Old Feb 25, 2006 | 10:35 PM
T-rex's Avatar
Seafoam.
Old Feb 26, 2006 | 10:39 AM
Z28LS1camaroguy's Avatar
do they sell seafoam at autozone and pepboyz b/c i can never find it
Old Feb 26, 2006 | 08:31 PM
T-rex's Avatar
I buy mine at Advance for about 6 bucks a can.
Old Feb 27, 2006 | 01:12 AM
Quickin's Avatar
Pep Boys and Discount/Advance Auto Parts always have shelves full of the stuff.
I used one bottle split into 1/3rd for the gas tank, PCV and oil....worked great. No more smoke when I go WOT
Old Feb 28, 2006 | 03:15 PM
11SECSS's Avatar
I've allways used BK44 cleaner
Old Mar 1, 2006 | 07:40 AM
Mr Incredible's Avatar
I use a variety of them. I figure at least one of them has to be good...
Old Mar 1, 2006 | 11:09 AM
YoMommasTA's Avatar
there are two that i use,chevron techron and lucas.but never ever use lucas in a used car unless you are sure its fuel tank-lines-etc are not corroded or rusted.the techron is fantastic for cleaning the injectors and intake deposits without loosening any rust ib the system causing headaches.the lucas is a fantastic upper cylinder lubricant and gas mileage improver.but it will remove loosen up all the rust and corroision.in todays cars that use part ethanol fuel after a few years of use you are going to see some corrosion in the system because ethanol is am oxygen carrying fuel.i guess you could start off useing small amounts of lucas,like 1oz per 20 gals then see what happens.but not in my used car!i've seen what can happen,it can really beat your wallet up!
Old Mar 1, 2006 | 11:31 AM
Bowtie Guy's Avatar
Chevron Techrolene. I get it at Costco. Comes in a twin pack. Spring and Fall.
Old Mar 29, 2006 | 06:51 PM
CARNAGE's Avatar
i use red line system cleaner it works great
Old Apr 5, 2006 | 05:49 PM
Dom's Avatar
Dom
So right before changing injectors would it be a good idea to clean the rust out of the lines? Should I use lucas then?
Old Apr 5, 2006 | 07:42 PM
Fast Eddie's 02 T/A vert.'s Avatar
What about some injector cleaner from NAPA. I read where you hook up this can to your fuel rail and take out the fuse for the fuel pump and run the engine. Has anyone heard of this, does it work?
Old Apr 6, 2006 | 06:56 AM
nytmare1's Avatar
Don't you mean BG44K?
That's what I use. Real good stuff. I put a can in my tank every oil change.
Marc
Old Apr 6, 2006 | 02:02 PM
MavrikTA's Avatar
I had an old busted *** chevy truck when I was younger. Ran ok, but alot of miles. Put a bottle of RXP in it and it came ALIVE. I worked @ Autozone and I had tried alot of diff. cleaners and boosters, but nothing worked like that tiny bottle of RXP. That is all I will use, personally.
Old Apr 23, 2006 | 05:51 PM
FireSilverLullaby's Avatar
Does anyone know about prestone 0-60 octane booster and fuel injector 2 n 1. I just baught it today at pep boys.
