Sponsored by: CARiD
horrible squealing
Old Feb 25, 2006 | 05:13 PM
dZ28adams's Avatar
Default horrible squealing
i have had this squealing problem since ive owned my car..every time it rains out or is damp out something is squealing for the longest time i thought it was my belts but i tried belt conditioner and that didnt work and i have 2 put up with this really loud squealing every time..it also increasing with acceleration..any ideas wut it could be?
Old Feb 25, 2006 | 05:35 PM
2fast97Z's Avatar
maybe your tensioner or a pulley but i wouldnt understand why it would only do it in the rain
Old Feb 26, 2006 | 03:52 PM
Lythropus's Avatar
Default Same Thing
Mine did the exact same thing, now it squeals all the time. I've replaced the belt tensioner and serpentine belt. It does not do it when I turn on and off the a/c so I'm ruling out the a/c idler pulley. I have no idea what it could be and the noise isn't easy to track.
HELP!
Old Feb 26, 2006 | 07:56 PM
Lythropus's Avatar
Default A Solution!
Change out the a/c belt. After changing out the upper tensioner pulley as everyone recommended, the main serpentine belt, I finally changed the A/C compressor belt and it cleared up right away. You can do as everyone recommends and put some dish washing soap on the lower belt to see if it stops it. If it stop then it is the belt and not one of the pulleys. I do warn that your car will smell like burnt dish soap even after you wipe it off until it all burns off. Hope this helps.
Old Mar 1, 2006 | 09:50 PM
dZ28adams's Avatar
yea i think im goin 2 give that a try...cause if i spray it it will stop for a moment then it starts back up again...so ill just replace the belt...thanx
