Sponsored by: CARiD
Light problem
Old Feb 25, 2006 | 07:40 PM
00scss's Avatar
Default Light problem
I need some help from you guys. When I start my car all of my lights flicker, headlights, interior everything. I am thinking alternator related. Anyone run into anything like this, or have any ideas? I think it is starting to do it more often now. TIA.
Old Feb 25, 2006 | 09:17 PM
2001whiteSS6spd's Avatar
I would check and make sure that your battery cables are tight. Happend to me before in my Iroc positive cable was a little loose. Hope this helps.
Old Feb 25, 2006 | 10:58 PM
00scss's Avatar
I will give that a look, thanks.
Old Feb 26, 2006 | 09:07 AM
j3ff's Avatar
I had the same problem, when u say flicker, do you mean pusling?
My cars headlights would always pulse...I went to autozone and got their remanufactured alternator.......works perfect now.
It wasnt the alternator that wasy bad, it was the voltage regulator, but that is inside the alt now.
Just swap it out and your problem will be fixed
Old Feb 26, 2006 | 03:26 PM
00scss's Avatar
That is what I was thinking. Just wanted to see if anyone else had the same problem. Thanks.
Old Feb 26, 2006 | 03:56 PM
2001NBMZ28's Avatar
My car always does that when the air pump cycles on a cold start. Not pulsing, but they flicker on/off - then stops once the pump shuts off. If you think that might be the case you can disable the pump by pulling the AIR PUMP fuse.
Old Feb 26, 2006 | 06:01 PM
00scss's Avatar
This is a continous pulsing.
Old Feb 26, 2006 | 06:14 PM
j3ff's Avatar
def your voltage regulator
Old Feb 26, 2006 | 09:11 PM
00scss's Avatar
Thanks. I will pick one up saturday.
