Sponsored by: CARiD
Cruise Control Removal?
Old Feb 28, 2006 | 11:34 AM
TRMIN8R's Avatar
Default Cruise Control Removal?
I searched and didn't find anything about removing the cruise control. Is there anything special I will need? Or can I just take the box out and just use the existing throttle cable? Anyone that has done this or can give me advice on what I will need?
Old Feb 28, 2006 | 08:44 PM
TRMIN8R's Avatar
Ok, well I removed the cruise control and now the throttle cables won't work. Do I need to buy a new one?
Old Mar 1, 2006 | 09:13 AM
TRMIN8R's Avatar
Someone has to know......
Old Mar 1, 2006 | 09:51 AM
thunderstruck's Avatar
im thinking that when you removed it, that piece on the cable that goes to the throttle body that you adjust it with separated and is just sliding back and forth.
Old Mar 1, 2006 | 10:13 AM
TRMIN8R's Avatar
That piece is off the car now, I think I'm gonna need a new throttle cable.
Old Apr 4, 2006 | 07:07 AM
rufretic's Avatar
I removed it too and took out the traction control unit. I was able to remove all three cables and both units for pretty good weight saving. I replaced the throttle cable with one out of a non tcs car, it goes staight from the throttle body to the pedal. Only problem is it has a slight bit of slack so I can't go wot. I thought it would be a direct replacement but I guess not. Now I need to get a spacer or figure some way to tighten up the new cable.
Old May 3, 2007 | 09:02 PM
K9 Pusher's Avatar
Digging this up from the grave because I'm doing this tomorrow. I have got the throttle cable from a non TCS car. Is there something I need to know to tighten the throttle cable?
Old May 4, 2007 | 09:10 AM
rufretic's Avatar
I just crimped a small piece of metal on the cable right by where it attaches to the pedal. You need to pull the pedal all the way up and see how much slack you have in the cable, then just find something to put on the cable to make up the slack.
Old May 5, 2007 | 08:41 AM
01WS6/tamu's Avatar
Easier way is to slide the plastic retainer on the pedal asm back then take a pair of needle nose pliers and pull a knot in the cable. But, before you do any of that I would try it there is no difference in the pedal asm between a car w and wo traction control. Now the cable bracket under the hood is probably where there may be a diffference which could cause the problem
Old May 5, 2007 | 01:47 PM
Splitz's Avatar
stupid question, why would you want to remove the cruise control?
Old May 6, 2007 | 09:02 PM
rufretic's Avatar
Because you can save some weight and clean up the engine bay getting rid of that whole assembly. If I remember right it includes the traction control too. When I upgraded to a 12 bolt I got rid of all that stuff. It's probly not the best idea for a daily driver, I rarely drive mine very far, hour to the track is the farthest I go.
Old May 6, 2007 | 10:07 PM
Splitz's Avatar
How much weight are we talkin' about? A few pounds or a few tens of pounds?
Is it REALLY worth it? Just curious that's all.
Old May 6, 2007 | 11:24 PM
01WS6/tamu's Avatar
The cruise module and tcs might add five pounds.
Old May 7, 2007 | 05:48 AM
Splitz's Avatar
doesn't sound like it worth it for me, but to each his own eh?
Old May 7, 2007 | 06:55 AM
rufretic's Avatar
It's not about the five lbs, it could have been 1 lb and it would still be gone. Everything adds up, anything that is useless to ME goes. It's about making the car faster and easier to work on. A lot of things are not worth it to some people and that's why there are a lot of slow *** cars out there.
Old May 7, 2007 | 07:20 AM
Splitz's Avatar
Undestood! Guess it all adds up in the long run huh?
Makes sense to me, i suppose just the convienance items only?
you remove the dashboard, lightening and so on?
Just wondering what extend the weight removal goes?
Old May 7, 2007 | 07:55 AM
rufretic's Avatar
No, nothing like that. I won't remove anything I use or anything that will hurt the looks.
