Sponsored by: CARiD
New Plug Wires...What A Difference!
Old Mar 3, 2006 | 09:16 PM
Travis99LS1's Avatar
damn i need to change my plugs and wires..i have 83K on the stock ones...A local dealer wants $165 for the OE AC delco wires...does anybody know where i can find them for a more reasonable cost?
Old Mar 4, 2006 | 09:07 PM
bad6as's Avatar
how do u mesure the ohms on plug wires?
Old Mar 4, 2006 | 09:28 PM
quiksilver9531's Avatar
I recommend you get msd wires on summit, the msd wires are like 50, better than OEM and they are the exact length as the old ones.
Old Mar 4, 2006 | 09:33 PM
T-rex's Avatar
Taylor thundervolt 50's. 10.4 mm.70.00 from Thunder Racing.
Old Mar 5, 2006 | 07:26 AM
Thanks alot man, i will be changing my plugs and wires in the next few weeks, and will definately order these. Thanks again.
Old Mar 5, 2006 | 02:42 PM
curtisad's Avatar
ok I will answer some questions for you guys. First off I am an electronics tech for then Navy. His new wires are NOT .850 ohms. He would have to have a meter that would cost three times his car to be able to accurately read something that low! His anything atround 5 to 15 ohms would be very good.
The more resistance you have in the wires the less voltage will be felt at the plug. Also resistance and heat are directly related. IE higher resistance=higher heat. That means lower resistance would mean longer lasting. (in theory that is)
that being said I have MSD wires which cost me around 50 bucks. They read around 7 to 10 ohms a piece. The old stockers read anywhere from 300 ohms to 800 ohms.
Old Mar 5, 2006 | 04:41 PM
Keysplayr's Avatar
Originally Posted by 2K2WS6TA
You might want to pop the ohm meter on them before you buy them, in somecases the autozone ones have a good amount of resistance from the start
Thank you my friend!! I just may have to invest the extra $15 for the MSD wires from Summit. So, I changed my plugs, and soon my wires. Then, I have the fun job of removing my transmission and sending it to Joe at T56 rebuilds.
I'm getting package 1A. While its out getting refurbed, I have my new OEM flywheel, clutch, PP, slave, and master to pop in. So, I have my work cut out for me. Sheesh!!!
Old Mar 5, 2006 | 10:25 PM
Black_Bird's Avatar
I had MSD's, had some go bad after 15,000 miles. Had alot higher resistance than my new OEM wires. Dont really think that the MSD's are better, most plug wires for these cars are about the same.
Old Mar 6, 2006 | 09:10 AM
bad6as's Avatar
the red z06 wires ok?
Old Mar 6, 2006 | 01:43 PM
Which wires are you currently running? What about accel? has anyone heard anything bad about these wires?
Old Mar 6, 2006 | 09:49 PM
Black_Bird's Avatar
OEM ones from the dealer.
Old Mar 7, 2006 | 07:52 AM
  #32
Mr Incredible's Avatar
Let me be clear, I am NOT an electech with the Navy.
My meter is a self-ranging meter from Sears and it's a pretty darned good meter for anything I'll ever do.
The reading was 0.850 Kohm vs 345 ohm. Does that mean 850 ohms? Then why is my car detectibly smoother now?
Since I'm no electech, please tell us what that is. I'm not being a butt, I just am not an electric kind of guy and presumed a bit.
Thanks.
Old Mar 7, 2006 | 08:41 AM
  #33
billybob59's Avatar
Thanks.
if ur meter was readin .850Kohms then yeh that would be 850ohms and sry i have no idea y it would be runnin smoother maybe cause ya put new plugs in cause ur new wires if that was ur reading is higher then ur old ones. went to college for electrical for 3 years just so ya kno
Old Mar 7, 2006 | 09:34 AM
  #34
bad6as's Avatar
so thoes $35 wires from the parts store wernt as flowing as you thought?
Old Mar 7, 2006 | 12:06 PM
  #35
Hmmmm...I rounded down in the wrong direction. Phooey. I hate it when I make mistakes. That's what I get for bein' in a hurry. At least I didn't cut myself this time.
Flowing? No. They weren't. Now I gotta find out why it runs smoother. I don't think it was the placebo effect, it was just too much of a difference. I made a three hour trip later that day and there really was a difference. Really! And I only changed the wires.
My sincere apologies.
Old Mar 7, 2006 | 07:13 PM
  #36
I found a cut and paste of a tech reference of an LS2 motor that cited the factory plug wire resistance of 700 ohms. I would think it wouldn't be any/much different of an LS1 spec. That's pretty high compared to the <100 ohm aftermarket wires cited by others in this thread. The wires I got at the parts store, at 850 ohm, is about 18% higher. That might be considered a lot, but with a high-resistance wire would it really be? Dunno. I obviously have much to learn about LS1 wires, and an entire afternoon of searching didn't lead me very far.
I also found a set of Granateli wires that advertised a gain of up to 15 hp. They were $186 and advertised 0 ohms. That's right, zero ohms. How do you measure that? Super-duper wires, indeed.
I understand the bit about less-resistance-is-more-juice-to-the-plug, but on a stock application which is most relevant....High (as in stock factory design pararmeters) or low (as in aftermarket)?
I suspect, then, my car running better would be a result of simply putting on new wires rather than super-duper wires (as they obviously are not).
But what quantifiable power increase has been had by using low and super-low resistance plug wires on an LS1...stock or otherwise? What is the spec on stock LS1 plug wires and why is it so high?
Trying to understand why the stock wires are designed so high and why everybody sells low resistance wires for our application. Does it really matter?
Old Mar 7, 2006 | 09:22 PM
  #37
savethelinoleum's Avatar
One thing we need to remember is that all of those plug wires that say "50 ohms" resistance say 50 ohms resistance per foot so when you measure the whole wire, it's going to have a different reading.
Old Mar 7, 2006 | 09:24 PM
  #38
Also, I'm looking at the YearOne catalog, they've got some Taylor wires that say 102,000 volts dielectric strength (they're big ones, 10.4mm), but they don't list a rating for the resistance. List price is $113/set.
Old Mar 7, 2006 | 09:36 PM
  #39
slowpoke96z28's Avatar
wires have higher resistance from the factory to prevent interference(see earlier in this threda where someone mentioned EMI/RFI) with low resistance the wires can cause radio interference and other problems. some super-low resistance wire that are not otherwise shielded can be heard when you have the radio on AM. you can even tune in to it(cant remember what station) so that is all you hear(its a trip, especially with someone else in the car). also it can interfere with emergency radioes. OEMs have to meet certain federal standards for emmitted energy, and the ignition system happens to be a big contributor.
Old Mar 7, 2006 | 09:52 PM
  #40
slowpoke thanks for the info. The MSDs claim not to have electronic interference. They claim that the tightness of their wind creates a "choke" on the interference:
"This choke, or suppression capability, keeps the EMI inside the wire where it cannot interfere with other electronics on your vehicle"
https://ls1tech.com/forums/generation-iii-internal-engine/457235-random-backfire-only-idle.html
If you go to that thread, the guy is saying that the resistance on his only "good" wires is 350 ohms, and that the resistance of his other wires is 1 to 4k and even "2 megs", which is as high as his meter went.
