Sponsored by: CARiD
Passenger side spark plug install issues
Old Mar 11, 2006 | 07:45 PM
kanewolf's Avatar
Default Passenger side spark plug install issues
Okay, I've done a ton of stuff to my "01 Z-28 vert. And I've also changed a bagillion sparkplugs in my life.
So why am I having such trouble accessing the passenger side plugs. The driver side was a pain in the butt. But the other side is like looking at a wall of parts. I tried going in from the bottom, not any better. Any suggestions?
Old Mar 11, 2006 | 08:01 PM
Go Faster's Avatar
Check out this site, it helped me alot!
http://www.installuniversity.com/
Old Mar 12, 2006 | 09:47 AM
kanewolf's Avatar
Thanks Go Faster!
I'm printing out the sparg plug page. Still feels weird having to move the indiv. coil packs and what not. I'll give it a shot though. Hard to get enough torque on the plug socket, replacing originals, so they are in there boy, driver side took at least an hour or 2.
Old Mar 12, 2006 | 10:32 AM
thechef's Avatar
Moderator
remove the whole coil pack assembly its just a few bolts, then reach in from the front of the car and you will be able to access the pass side much easier
removing the coil packs from each side is the only easy way to do the pulgs on a ls1
Old Mar 12, 2006 | 10:39 AM
davered00ss's Avatar
Moderator
I kneel on the battery and lean over the engine and do #8 by feel.
Old Mar 12, 2006 | 10:40 AM
Moderator
The easy way. lol
Old Mar 12, 2006 | 10:56 AM
MrEddie's Avatar
Yeah, the passenger side takes a while. The last bolt on the coil pack is tricky. I left mine off because I don't want to deal with it again. You have to go by feel on a couple of the passenger side plugs, but it's not too bad.
Old Mar 12, 2006 | 07:17 PM
jims73z's Avatar
I bought a ratchet with a flexible head at kragens that gave
me the odd angle for the back passenger plugs.
http://www.partsamerica.com/ProductD...tnumber=641506
Old Mar 12, 2006 | 07:39 PM
kanewolf's Avatar
Thanks all!
I had trouble buying the right plug-wrench. Which was part of my problem. I'm a little tall to fit under the hood like Davered))SS, so I'll have to put some serious back strain into it. Wish me luck!
Old Mar 12, 2006 | 08:07 PM
2kta--89formula's Avatar
I did mine without removing the coil pack......# 2,4,6, from up top, # 8 from the bottom. It helps to have skinny forearms, and it looked like I dragged them over a couple miles of barbed wire when I was done.
Old Mar 12, 2006 | 11:12 PM
2000BLKSupersport's Avatar
I did mine in about 3 hours, only had to move the pass. side AIR fitting to get to 2,4,6,8. 8 took a little time but it pays to have slimer forarms.
ALL in ALL wasnt too bad.
