Sponsored by: CARiD
Who has changed a door pin?
Old Mar 18, 2006 | 09:08 PM
Studytime's Avatar
Default Who has changed a door pin?
I'm getting really tired of my driver's side door sagging, popping, and creaking. It's time to fix it. I was just wondering who has changed their door pins to fix this problem. If you changed them, how did it go for you?
Where did you get the parts?
Ben T.
Old Mar 19, 2006 | 02:36 PM
THE CHOP SHOP's Avatar
I have tha same problem and have posted before with no response. I was looking thru an eastwood catalog and saw that they sell a tool to remove the spring. I think if that was out of there it would be easier. I hope someone can chime in cause mine is bad as well.
Old Mar 19, 2006 | 03:43 PM
2manytoys's Avatar
I replaced the pins and bushings on my 87 IROC but it did not fix the door sag problem. That spring is a b!tch.
The TA i just bought has problem with both doors. Someone help!!!!!
Old Oct 11, 2010 | 05:04 PM
AR15 guy's Avatar
I am going to bring this thread back from the grave...
I need to know how to change the lower door pin and roller bushing...mine is trashed.
Old Oct 11, 2010 | 07:20 PM
johnnybravo's Avatar
I took mine to the local Chevy dealer. The body shop guy said it was a common issue with these cars. I had them replace both top & bottom hinge.
It was around $170 or so installed. Drivers door.
Old Oct 13, 2010 | 01:48 AM
01ssreda4's Avatar
Yes, I dont believe these are serviceable type hinges either. I believe you have to replace the hinge as one piece.
Old Oct 13, 2010 | 04:06 AM
It's been a year or two, but I think the Chevy guy mentioned that, that's why I had them replace the whole hinge, plus the other one since I figured it had been stressed.
I really didn't want to to attempt it myself, that's one heavy door.
Old Oct 14, 2010 | 08:56 AM
01ssreda4's Avatar
^^^They are fiberglass dood!!!
Old Oct 15, 2010 | 12:41 PM
AR15 guy's Avatar
Problem is the dealer shows the lower hinge is discountinued....
Now what? Get a used POS?
