Sponsored by: CARiD
for light replacement
Old Mar 19, 2006 | 12:51 PM
delinquent543's Avatar
Default for light replacement
stupid question, but how do you replace a fog light? the screw to take it off doesnt seem to want to budge.. is there a spring or something in it? thanks
Old Mar 20, 2006 | 11:40 AM
chrisryn64's Avatar
It's weird but you have to change the bulb from under the car. If you look right under the bumper near the front air dam there are 3 bolts on a little flap under the light assembly called the access door. Take those bolts out and the door opens then you can reach in there to pull the bult out and replace it.
Old Mar 20, 2006 | 04:37 PM
Kirby's Avatar
Which vehicle is it? They're both different. And don't do the camaro headlight removal to change the fog light bulb. That is like taking off your oil pan to drain your oil. Just get to it from the bottom. 2 screws to the flap on each side and just reach in and twist them out of the socket. It takes a total of 5 minutes to to them both.
The above was for a camaro. I'm not sure on the difference for a trans am. Shouldn't be much different.
