Sponsored by: CARiD
Interior lights "flashing" at idle??
Old Mar 19, 2006 | 09:25 PM
frcefed98's Avatar
Default Interior lights "flashing" at idle??
Is my alternator taking a crap? My interior lights, like the radio display, gauge cluster etc..are all flashing, its really subtle. My voltage is 13.8 when the car is idling?
Any help would be great, the car just started doing this, and its the original alternator that the car came with so I'm glad it made it this far
J
Old Mar 19, 2006 | 09:31 PM
Z28LS1camaroguy's Avatar
go get it tested at autozone or pepboys to see if the alternator is goin out or could be a simple battery problem, check it then replace it, its free anyways at autozone or pepboys.
Old Mar 21, 2006 | 07:25 PM
MIKE_84's Avatar
sounds like the voltage regulator
Old Mar 21, 2006 | 08:51 PM
frcefed98's Avatar
Found out today, dying alternator I ordered a hi output unit from a sponsor here on the board Thanks guys for the help
Old Mar 30, 2006 | 07:42 PM
Camaro_SS's Avatar
WHAT HE SAID! If you have consistent voltage over 12.8v at idle, then you're alternator is fine! Especially since you stated 13.8v at idle. Most common reason for the "flicker" is a failing regulator.
Old Apr 2, 2006 | 11:11 PM
The Golden One's Avatar
I have the same problem How much to replace the part how hard is it to change the part and how much does a new Voltage Regulator run???
Old Apr 2, 2006 | 11:14 PM
is it the Voltage regulator to the alternator or cluster insturment regulator???
Old Apr 6, 2006 | 06:08 AM
ls1z28chris2's Avatar
Question
Mine have been flickering slightly for a while now, but this morning it was pretty bad. Anyone have info on the voltage regulator part number and how to replace it?
Old Apr 6, 2006 | 01:06 PM
LS1MONSTER's Avatar
I was gonna say it's most likely the air pump coming on and off...but then I saw your mods and crapped my pants.
Old Jun 21, 2006 | 08:02 PM
MIKE_84's Avatar
voltage is built into the alternator, so basically a new alternator is needed.
