A/C Compressor gone, can i use a used compressor?
also there is already a filter in the system already you don't add one
what do you think the reciever dryer or accumlator's job is?
also freon is duponts nick name for r-12
and more then 3% contamination in the system causes problems
like travis said, moisture does cause acids to form when it reacts with refrigerant(thats what i was refering to when i was talking about the compressor seizing up), but like i said, IMHO, its still worth the risk if you can find a non-seized compressor for cheap enough. most salvage yards evacuate the system when they dismantle cars, so there should be no refrigerant for the moisture to react with. i personally think the hundreds of dollars you stand to save would be worth the risk.
whats the desicant bag in there for
most likely a compressor that was on the way out, everything else was done right though. now i have a new compressor and it is getting no power, its been like that for months and i heard all the seals and stuff are probably f'ed from the system not being active the whole winter.
Do you know of any filter that would fit? The way the fitting is on the back of the compressor I don't know of a part that would work offhand. I know the compressor has a filter on the inlet. There is not really any space for a filter element to rest on when looking at the outlet.
Real Freon can still obviously be purchased if you know how. However, I have heard that the real reason for the switch was to protect the market due to a patent's lifespan. The actual difference in performance is not supposed to be revolutionary so real Freon is probably not worth the purchase price.
I don't know if traces of water vapor in the AC system, lets say you didn't vacumm... or it was so humid that water vapor was left even if vacumned... would be enough to corrode the system in a short period of time. (Year maybe?) Would this water vapor remain as water vapor or be absorbed into the mixture???
I am sure it would have a severe effect on the compressibility of the refrigerant and at what T/P it changes state leading to reduced system performance.
temperatures on the discharge side get pretty hot but maybe you could put a filter on that side IDK tho
yes...even the smallest amount of moisture in the system can cause major problems. 20 Parts Per Million of moisture in the system can cause a metering device to freeze. Not to mention as already stated before, moisture reacts chemically with refrigerant to form acids. The heat generated in the system will speed up the acid forming process. They do have filters you can add, usually to the liquid line and the suction line, which is usually recommended after a compressor failure.
