Sponsored by: CARiD
how to change foglights
Old Mar 25, 2006 | 04:43 PM
pewterbirdls1's Avatar
Default how to change foglights
I lost cover to my drivers side foglight , i got a replacement light..How do i get to light i see a screw holding light top but also seem bolted at bottom, do i need to remove entire shroud underneath car? i tried to access thru trap door with turn single bulb is but i cant reach..do i need to lift car ? any help would be appreciated .car is 1999 trans am
thanks
Old Mar 25, 2006 | 05:03 PM
98ls1vert's Avatar
the fog lights on the t/a are attached to a bracket that has two bolts side by side, but I'm not sure if you need to take the front bumper cover off. I recently changed mine, but I did it when the bumper cover was off anyway. Good luck.
Old Mar 25, 2006 | 05:10 PM
johnnytransam's Avatar
is it the same procedure as a 1993 t/a?
