Sponsored by: CARiD
Help diagnose this noise
Old Mar 28, 2006 | 09:29 PM
mike#9's Avatar
Default Help diagnose this noise
When I turn the wheel one way I get a clunk in the steering wheel....seemingly coming from the column up to the steeringwheel. Then when I turn it back the other way it does it again....and it keeps doing it when I turn the wheel each way.
What do you guys think it is?
Thanks for any help!!
Mike
Old Mar 29, 2006 | 09:12 AM
mike#9's Avatar
any guesses
Old Mar 29, 2006 | 10:30 AM
Ian300D's Avatar
Check your tie rod ends. And various control arm bushings to make sure they are top notch.
Old Mar 29, 2006 | 10:47 AM
mike#9's Avatar
Thanks....any other suggestions?
Old Mar 29, 2006 | 09:09 PM
Tall Guy's Avatar
You should also check the steering rack mounting bolts too.
Old Mar 29, 2006 | 11:14 PM
MM98's Avatar
Normally a clunking noise would indicate a worn out intermidiate steering shaft... You can see it on the driverside by the exhaust manifold... Might try lubing it & if that doesn't work you might just have to replace it... The fullsize 99-02' chevy/gmc trucks where real bad about this & even had a bulletien on it.
Mike
Old Mar 30, 2006 | 11:51 AM
mike#9's Avatar
I dont know if this helps or not...but the car sits for about a month to 2 months at a time. Is any of the things that it could be really expensive??
Thanks a lot guys....this sort of thing is outside of my expertise
