Sponsored by: CARiD
Misfire source?
Old Apr 15, 2006 | 04:37 PM
98Z28MrO's Avatar
Default Misfire... ?
I have a misfire trouble code popin up. So far ive changed 7 out of the 8 plugs and the wires are not that old. What are the chances that the 8th plug is causing it? Also, what are some other possible causes for the problem?
Thanks
Bryan
Old Apr 16, 2006 | 12:46 PM
Billy177's Avatar
about a 1 in 8 chance that it is causing the misfire.
i would make sure all the plugs and wires are good then check for any vaccum leaks or anything like that
Old Apr 16, 2006 | 12:54 PM
98Z28MrO's Avatar
haha i was thinkin more like 1 out of 24..
Old Apr 16, 2006 | 01:02 PM
camaroguy26's Avatar
just go to autozone to have the codes scanned. They'll do it for free if you have a light coming on. It will show which cylinder is misfiring. It could be a plug that is cracked, the wires are loose, maybe even the coil failed. It does happen, very rare for a coil to fail but who knows.
Old Apr 16, 2006 | 02:53 PM
BLKWS.6's Avatar
make sure the wires "click" when you put them on. Sometimes they can be a booger on my 5.0 to get em' to snap.
Old Apr 16, 2006 | 03:28 PM
98Z28MrO's Avatar
I have hp tuners which is why i know what the code is... but i didnt think it showed the cylinder number with the code.. Maybe i just didnt pay enough attention.. I have a feeling its one of the wires, i just need to double check if they are clicked or not.
Thanks for the help guys.
Bryan
Old Apr 16, 2006 | 04:03 PM
BLKWS.6's Avatar
FYI, i had a crown vic with a 5.4L motor out of a 98 F150. When we first ran it around hte block, it was raining. wouldnt even spin a tire...we replaced all the plug wires and it would spin em pretty mean in the rain and ok in dry weather if you tq braked a little. plug wires gave it at least 30-50 on the low end. HUGE difference, dont discount that a plug wire may be broken inside.
Old Apr 18, 2006 | 06:36 PM
Travis99LS1's Avatar
Dont forget it doesent have to be ignition related to cause a misfire....It could be a misfire from an overly rich condition in a cylinder...or it could be a misfire from an overly lean condition....it could be mechanical misfire....You really need to look at some stuff on a scan tool, or an exhaust analyzer to get a better idea of the possible causes..
