Sponsored by: CARiD
Smoke!, video
Old Apr 15, 2006 | 07:19 PM
kukri's Avatar
Default Smoke!, video
2001 LS1, only mods are Headers and Exhaust. It has 41k miles on it. Here is a video of me at the autocross today
Click here to watch Run-3-Top-Gun
It is in the rx7. You can see those puffs of smoke come out a couple of times. It usually happens when i downshift or just let off gas to take the corner. Could it be the head gaskets going? Also, just wanted to note that I keep about 7 qts of oil in it (stock oilpan).
Old Apr 15, 2006 | 07:27 PM
Nick98Z28's Avatar
my friend tells me he sees my car puff out smoke. My car also has no cats my assumption is thats why.
Old Apr 15, 2006 | 07:29 PM
kukri's Avatar
my other rx7 with a small block setup has no cats and it doesn't smoke, only except when it cranks.. But yes, I do not have cats on this car
I have heard about oil getting into intake somehow...is that a bad thing? How does it get into the intake? What are the solutions? Im not sure if I have room for oil catcher in there.
Old Apr 16, 2006 | 01:19 AM
kukri's Avatar
To The Top.
Old Apr 16, 2006 | 10:33 AM
thechef's Avatar
Moderator
well 7 qts is TO MUCH to start with
you should not have more than 5.5 tp 6 qts in a ls1
Old Apr 16, 2006 | 01:48 PM
kukri's Avatar
Well a lot of people searched about that and found out that you can put 7 qts in it with the stock oil pan. I wanted to make sure there was no starvation during the corners.
Old Apr 16, 2006 | 05:00 PM
kukri's Avatar
This section of forums is not very crowded huh
Old Apr 17, 2006 | 02:35 PM
waiting2bl33d's Avatar
yes, depending on the year of your LS1 you could have a bad PCV system check installuniveristy for the fix on this. and if you've ever taken off your intake on the LS1 you will see alot of oil in it and w/ headers it should make the problem more appernt
