Sponsored by: CARiD
oil/filter question
Old Nov 7, 2002 | 03:56 PM
Patman's Avatar
Default Re: OIL/FILTER QUESTION
Castrol Syntec is labelled as a full synthetic, but it is really not, it uses a group 3 base oil, not a PAO/ester base like a real synthetic does.
Read here for more info on how Syntec is a ripoff:
http://www.1st-in-synthetics.com/articles5.htm
Old Nov 7, 2002 | 08:32 PM
fak005's Avatar
Patman,
I am planning to go with Mobil 1 10W30, what filter do u recommend if I am going to be changing oil every 5000miles? Mobil1 or AC delco....also whats differnce between long/short filter?
Can short filter also last 5K miles? If not, how much can long filter hold?
THx
Adnan
Old Nov 7, 2002 | 09:06 PM
01Z0H6's Avatar
Mobil 1 5W30 & Mobil 1 filter!
Been doing this since i got the car Dec 99(new)
Currently have 72K. Oil & filter changed religiously Q 5K......... <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Nov 7, 2002 | 11:55 PM
SSDude's Avatar
Go with Mobile 1 and Mobile 1 filter M206 (the long filter). It will hold more dirt thereby keeping your car cleaner. Since you live in Texas, you should use 10-30 oil and change your oil every 3,000 miles. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 8, 2002 | 12:10 AM
wicked 98z's Avatar
So how many miles should you change your oil at? I change mine every 2000k miles with the long oil filter and moble one 5w30. Can i change it longer?
ALbert
Old Nov 8, 2002 | 04:18 AM
Patman's Avatar
You can definitely go way longer than 2-3k on Mobil 1! Go at least 5-6k, since it's good to go way longer than that even (10-15k is a piece of cake)
The stock sized filter will last 5k, however the longer one will filter better since it's less of a restriction to oil flow so it goes into bypass mode less often (this happens a lot when the oil is cold or when you drive hard)
I'd go with the M1 over the AC Delco.
<small>[ November 08, 2002, 04:20 AM: Message edited by: Patman ]</small>
Old Nov 8, 2002 | 08:14 AM
Ben99Z28's Avatar
One of my friend is a chemical engineer and he recommended Amsoil, I'd switched from royal purple to Amsoil last year and so far so good, the oil still look fresh at 7000 miles, oil consumption problem had dropped, only used 1qt every 3000~3500 miles, I use 5w30 and oil pressure always stay close to 60psi, Amsoil said it could last 25K miles but I changed mine at around 15K, it's like $5.50/qt here which is same as Mobil 1, so I think it's pretty good deal <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> but don't know why not many fbody folks use the Amsoil tho. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Nov 8, 2002 | 08:25 AM
JWRENCH's Avatar
Hey thanks for the Amsoil link Patman. I found it pretty interesting.
Old Nov 8, 2002 | 05:25 PM
fak005's Avatar
those of u that change oil, what time duration do u change it at
is it 5000miles and how many months?
or 3000 miles or how many months?
THx
Old Nov 8, 2002 | 05:32 PM
LS1droptop's Avatar
I changed my oil and filter after the first 2000 iles.I use Moble 1 5W30 and stock GM filter.I plan on going with the longer one next year.My car has the sensor for the oil.That is supposed to tell you when to change it.In the manual it says if you do not put alot of miles on the engine.You should change it at least once a year?What do you guys think?
