Sponsored by: CARiD
WTF is my car doin?
Old May 16, 2006 | 08:40 PM
Iam2bewit's Avatar
Default WTF is my car doin?
Sometimes when I nail it, It stalls out. and the more gas i try to give it the more it bogs down? changed fuel filter. Dont know what else it could be. Cam, all bolt ons, and tune. and a racetronix fuel pump
Old May 16, 2006 | 08:46 PM
fastfbody's Avatar
the belongs in the tech area. but it sonds like a ignition issue
Old May 16, 2006 | 08:47 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
let the clutch out slower... LOL
Try the tech forum.
Old May 17, 2006 | 08:55 PM
meverf's Avatar
Tellus more about the car, year, motor and such.
Old May 17, 2006 | 09:58 PM
Iam2bewit's Avatar
99 t/a... thunder 220/220 cam, three angle valve job, flowtech headers,racetronix fuel pump, weiand intake, 2800 stall, ngk plugs. And Im runnin a dry shot of nos.(100shot). and the car was tuned.
Old May 17, 2006 | 10:16 PM
ChocoTaco369's Avatar
Tech Resident
maybe you need bigger injectors?
sounds like you got a lotta **** done to it, so when you nail it, the injectors cant deliver enough fuel causing it to stall out. you may need bigger ones?
OR
you have a leak in a vacuum line?
Old May 17, 2006 | 11:10 PM
staringback05's Avatar
yea u got a aftermarket fuel pump and stock injectors?....thats a lil off
Old May 17, 2006 | 11:22 PM
snake charmer's Avatar
What was the last thing you did to the car before it started to do this ? Also , could you describe in more detail just how it bogs down as in how many rpms you are pulling, when it starts to bog stuff like that ?
The more detail that you give the more someone on here could maybe help you out .
Old May 18, 2006 | 10:06 PM
Iam2bewit's Avatar
it runs fine as long as I ease into it, like just givin it a steady dose of gas. but if I try to pass someone, and floor it or something, it's like it wont take anymore gas. and I have 28pd injectors, so im sure im fine in that area. It's normally in the higher rpm area. like im runnin 80 or 90 and then i nail it it wont do a dam thing. kinda feels like it wants to shut off or something. but if i just keep easing into it.... it will continue to pick up speed
Old May 18, 2006 | 10:11 PM
Iam2bewit's Avatar
the last thing i did was add that fasttoy ram air thing. and yea it sucks
Old May 18, 2006 | 11:11 PM
I would start checking the little things first . First I would pull the spark plugs and check those or just replace them if that has not been done yet . I had a crack in a spark plug when I did a swap and did not notice it till I got down the road . It did not throw any codes or nothing just when I would get in the gas above 3500 it would miss and studder but if I barley gave it some gas it would climb no problem . Spark plugs can be delicate and sometimes they fall when being handled in the auto stores and develop hairline cracks .
Old May 19, 2006 | 02:16 AM
'Trust''s Avatar
Sounds like a cracked plug to me.
