Sponsored by: CARiD
Plugs
Old May 18, 2006 | 09:51 PM
losiguy's Avatar
Default Plugs
Well I went to pull a plug out today just to see how bad they were ( I found out after I bought the car, the car was sprayed)
They are fouled pretty bad, definitly been sprayed on. Heres the worst part...they were gapped at .070
I put the stock one back in for now, changing all saturday to TR-5. These come pre-gapped at .35 correct? I checked them with my gapper and then all said .035. Would this be fine to stay at for daily driving? I plan on spraying nitrous way down the road, but heads/cam and a stall first.
Thanks.
Chad
Old May 18, 2006 | 10:15 PM
2K2WS6TA's Avatar
If you're going to use the gas, TR 6 is what you want, but until then the TR 55s will be fine
Try a search for the reccommended gap (can't remember off the top of my head)
Old May 18, 2006 | 10:22 PM
227Hawk's Avatar
TR-5s for N/A is fine. When you get to spraying swap to TR-6s. And if you're stock open the TR-5s to .038- .040
Hawk
Old May 19, 2006 | 01:09 AM
1QuickBlkZ28's Avatar
For a stock car I was told to gap the TR55's at .50
Old May 19, 2006 | 03:10 AM
chpmnsws6's Avatar
why are you mad its been sprayed on if your also going to spray it? is it like sloppy seconds or something?
Old May 20, 2006 | 12:14 AM
losiguy's Avatar
Yes...And the fact he was spraying on .070" gapped plugs.
I did the driver side today. I just put the TR5's in gapped at .038" ...will this be ok to daily drive on n/a of course?
Old May 20, 2006 | 12:21 AM
staringback05's Avatar
u can go with the ac delco iriduims to...there pretty good plugs, ive heard everything from gap....0.05 to .038
Old May 20, 2006 | 04:01 PM
chpmnsws6's Avatar
iriduims and nitrous? i don't think so.....
Old May 21, 2006 | 12:26 AM
didnt see the spray part...thought he just said the engines BEEN sprayed before and i didnt think he was gonna spray it anymore
Old May 21, 2006 | 01:42 PM
losiguy's Avatar
I just went with TR5's at .038...car runs alot smoother and feels more responsive. Thanks for the replies.
Old May 24, 2006 | 09:05 PM
ZoFastSS's Avatar
.035 on the TR6's and .054 to .057 on the TR55's
Old May 27, 2006 | 01:16 PM
Mike02Z's Avatar
Wow, everyone seems to use a different gap. I was going to use .050 for my new TR55's but now I'm wondering....
I found this for the iridium plugs...
http://www.acdelcotechconnect.com/pd..._03D-J-171.pdf
That says .040
Old May 27, 2006 | 02:00 PM
bene's Avatar
Trunion King
Okay, lets have one committed answer here. Is it +/-.38 gap? or +/-.50 gap? Immediate response is appreciated because I'm about to install these plugs in a few minutes.
