Sponsored by: CARiD
DRL/Turn Signal Problem...help
Old Jun 6, 2006 | 01:46 PM
Tropi-Care Jason's Avatar
Default DRL/Turn Signal Problem...help
okay...so my DRLs and turn signals on the front of my firebird aren't working...the bulbs still work...they'll come on when you turn the parking lights or headlights on but they don't get brighter for the DRLs whenever the parking brake is down...so b/c of this i also don't have blinkers on the front...still flashes fine in the car and on the back...flasher was replaced not too long ago...was hoping it was just a fuse but didn't find a DRL fuse...anyone else had this problem or know how to fix it???
Old Jun 6, 2006 | 08:29 PM
Pewterpower's Avatar
Change your bulb.
Old Jun 7, 2006 | 12:50 AM
Originally Posted by Pewterpowre
Change your bulb.
the bulbs are good
Old Jun 7, 2006 | 06:49 PM
anyone got any other ideas?
Old Jun 16, 2006 | 11:00 AM
DamonNC's Avatar
I think the same thing just happened to me. Yesterday I noticed that when I tried to use either turn signal, I just got a solid green light indicating that the signals aren't working. My DRLs do not work, and the signals do not blink, but my parking lights will come on when I turn the headlights on. I checked both bulbs and they are both still good (both were replaced a few months back). So the DRLs/turn signals will not light up, but the parking lights will light up only when I turn the parking lights/headlights on. Is this the same problem that you are having? and does anyone know how to fix this?
Old Jun 16, 2006 | 01:06 PM
Enob2205's Avatar
I've had and have again, this DRL/ turn signal problem. The first time it happened It took me forever to figure it out, but I did find my problem. It was simply corrosion inside the connector. The corrosion was from condensation building up on the inside of the lens and collecting in the bottom, right where the bulb is. Simple fix was to get the corrosion out with a small flat head screwdriver. (note: there are four small pieces of metal inside each connector. Two on one side for turn signal and two on the other for DRL.) My DRL and turn signals both worked fine after I was done, until now.. I think I have the same problem again. I'd say its just a bad design.. I hope I was helpfull. Good luck
Old Jun 17, 2006 | 07:37 PM
DamonNC's Avatar
figured it out! The corrosion inside the connector had caused the connection wires on the bottom of the bulb corrode to the point where the DRL/Turn Signal connector wire corroded off completely. Just had to change out both bulbs and it was fixed...for now
Old Jun 18, 2006 | 01:43 AM
my turn signal indicator in the car still flashes like normal and the rears blink just fine, but yeah the parking lights still light up when turned on
Old Jun 18, 2006 | 01:45 AM
gonna go to walmart tomorrow and pick up some new bulbs and see if i can fix this problem!!! thanks for the help guys...hopefully it works!!!
