Sponsored by: CARiD
My tach is off... any fixes?
Old Jun 8, 2006 | 09:42 PM
LS1Formulation's Avatar
Default My tach is off... any fixes?
I swapped to 4.10 gears today and haven't reprogrammed my speedometer yet, but I was attempting to guesstimate my MPH through my RPM using f-body.org's gear calculator. I drove past one of those portable radar trailers and my RPM is off by 3-400 rpm, as in it reads 3-400 rpm higher than it really is. I've heard the stock tach is off, but I didn't think by that much. I've been shifting at the track at 6000 RPM, but if it's off that much, I should be shifting closer to 6400. I don't really want to put an aftermarket tach in my car to fix the issue. Does anyone have any experience with this, and if so, what did you do to fix the problem? Also, should I alter my shift points? I heard the rev limiter is set at 6200, so trying to shift higher probably wouldn't work, if the PCM is reading the same values as I am seeing on the tach.
Old Jun 9, 2006 | 02:11 PM
outkast6991's Avatar
yup factory tachs are almost always off from what i've read.mine is off about 450 at idle so i'd say check yours with autotap to be sure
Old Jun 9, 2006 | 03:22 PM
Mike02Z's Avatar
At least it's off in the better direction. Being 3-400 rpm higher than actual rpm is better than being 3-400 lower when your trying to shift at 6200 rpm
From what I gather the fbody tach in general is not very accurate.
Old Jun 9, 2006 | 04:03 PM
Zymosis's Avatar
I'm suprised its off that way as well. Usually the tach in the dash is unable to keep up with accelerating engine speeds. I hit the rev limiter once....at like 6k....limiter set at 6500.
Old Jun 9, 2006 | 04:58 PM
C.J.'s Avatar
been there done that, the tachs are rediculously slow.
Old Jun 9, 2006 | 06:37 PM
natronathon's Avatar
according to my HP tuners, mine isn't off by that much... maybe 100 or so... but thats it...
Old Jun 9, 2006 | 08:39 PM
BrandonDrecksage's Avatar
get a shift light....I always thought our tachs were slow(I know i've hit the rev limiter in 1st when the tach read 5500rpms...hence why i got a shift light..in the ac vent..hidden)..not off. cause I know cruising on the highway and at idle..mine is nearly perfect.
Old Jun 9, 2006 | 08:54 PM
Mike02Z's Avatar
I've actually got pretty good at shifting by sound. The GMMG makes that a bit easier. I never liked looking down when accelerating hard. I prefer looking at the road. The shift light would probably be a great idea. At least you can see that out of the corner of your eye if mounted in the vent opeining.
Old Jun 9, 2006 | 09:02 PM
its bright...a car 5 car lengths behind you can see it light up...lol
