Sponsored by: CARiD
cure for detonation?
Old Jun 16, 2006 | 02:38 PM
Fire-formula 93's Avatar
Just drove my moms 99 TA and hers did the exact same thing! Anyone got any suggestions? It is not a metallic sound. It is a raspy/popping sound. My girlfriends thoughts were that there is a piece of paper in the engine
Old Jun 16, 2006 | 02:40 PM
Tobynine9's Avatar
That's probably it.
Old Jun 16, 2006 | 07:57 PM
Sunset'01Z's Avatar
ok guys, tomarrow im planning on !PCV system. i heard that could possibly do it so i'm gonna try it out. i'll report on this thread later if it works.
Old Jun 16, 2006 | 09:14 PM
pewter99ls1's Avatar
Arrghhh!!! Seems like all us Texas guys are having this "pinging" issue. One thing that did help for me was cleaning the MAF elements and then resetting the computer. Don't know if one or the other made the difference, but my pinging went away. I do have a catch can by the way.
Old Jun 16, 2006 | 10:22 PM
Sunset'01Z's Avatar
its cuz it gets so f*cking hot down here lol
Old Jun 16, 2006 | 11:14 PM
rayvendawn's Avatar
*cough*texasheatsucks*cough*
Maybe there is something in the gas down here..
Old Jun 17, 2006 | 01:10 AM
Sunset'01Z's Avatar
could also be that our air is pretty dirty.. smog and stuff liek that is hard for air filters to clean up
Old Jun 17, 2006 | 01:29 AM
Hey I am up here in Missouri, both mine and my moms car makes this noise. EXACTLY the same also and does it under the same circumstances.
Old Jun 17, 2006 | 04:02 PM
Sunset'01Z's Avatar
ok guys, here it is: i just installed MSD wires, and TR6 Plugs. i'm guessing the colder plugs cured it
Old Jun 17, 2006 | 06:38 PM
JD_AMG's Avatar
Yeah, missouri heat sucks.
So it wasnt the heatsheilds or 02 sensors that made the noise?
BTW are you on FAST?
Old Jun 17, 2006 | 07:24 PM
Yes I am on FAST. My name is Speed Density because I used to have a 93 Formula. I live in St. Peters Also.
Great job Sunset'01Z!! Looks like I am doing some tr6 plugs real soon.
Old Jun 18, 2006 | 09:33 PM
  #32
JD_AMG's Avatar
Oh yeah, you just recently got that T/A didnt you? Beautiful car. Id like to hear this 'ping' you got, see if it sounds like what I had.
Old Jun 19, 2006 | 12:34 AM
  #33
Sunset'01Z's Avatar
i wonder if the colder plugs affected my na performance though.. seems more like a bandaid covering the wound instead of fixing the problem.
Old Jun 19, 2006 | 02:49 AM
  #34
Yeah I thought about that too. Did you try the stock temp plugs? I mean what else would cause of this sort of detonation? I immediately think that new plugs and maybe even wires should be installed.
I know the oil vapor from the PCV system can cause this high rpm detonation but I have already installed a home-made catch can that is working quite well by the looks of it. I have a nice puddle of oil in the bottom of the glass after only 3 days of driving.
What else? Carbon buildup? I doubt it. Even if we seafoamed our cars the problem would eventually come back if carbon buildup is the culprit.
So even if colder plugs are a "bandaid", IMO it is the best fix for us, to my knowledge at least.
Old Jun 19, 2006 | 02:08 PM
  #35
Sunset'01Z's Avatar
good point. well the only other thing i know of is to delete your pcv system all together, but then you will have to get a breather oil cap and that leads to the oily **** all over your engine bay.. i had one on my old ford truck and it was fairly messy. it didnt have detonation though, i just didnt like the pcv lines
all i can say is try it. colder plugs seem to have done the trick for me. goodluck to you dude.
