cure for detonation?
edit: i'm only going to use a "catch can" as a last resort.. i dont want an ugly *** can in my engine bay.
sounds like u might need a good top end cleaning, also a catch can to keep any oil from going into the intake.
My car wasnt as bad but was pining slightly under wot and under low rpm loads. I believe the top end cleaner from the gm dealer and catch can helped quite a bit.
I will find out when i get back on a dyno / computer being scanned as well.
The thing is though... I already have an AMW catch can. I'm running MSD wires with TR55GP plugs gapped at .050.
What is top end cleaner? Like Sea-Foam? I've been using Sea-Foam every oil change and it always blows lots and lots of smoke.
Wassup with my car?
I will check for rattling shields but I really dont think that is what it is. It sounds BAD. Not like something rattling but more like something crackling. It seems the more load the engine is under, and the hotter the weather, the more it makes the noise. It gets really bad in 3rd gear but today it was so bad it even did it in 1st. I am going to take it easy and I really want to get my car scanned ASAP.
I have replaced the fuel filter, changed oil, and always used 93 octane (also tried different gas companies). Plug wires are MSD super conductors. Also, I have no service engine lights.
Someone help us!
I tried cleaning my MAF and it didn't help much...I bought my gas at an EXXON and there is no more detonation (93 octane BTW).
All of this in *100+ temps (If you like HEAT,you will LOVE South Texas!
). I get my gas at different places and it still does it. I am going to drive my moms 99 TA and see if hers does it.
All we did was take some needle nose plyers(or a tool similar, sorry im no mechanic) and squeezed the metal down on the 02 sensor.
Someone help us!
Definetly check for loose exhaust components and heat shields etc. Mine was a very metalic knocking/poping/pinging sound, would also do it in 1st on a hot day, and only under WOT.
Damn cars are friggen weird...
Could it be the catalytic convertors breaking apart inside?
