Sponsored by: CARiD
HELP ME!! loud squeal, throwing belts!!!!
Old 06-17-2006 | 03:16 PM
trouse40's Avatar
Question HELP ME!! loud squeal, throwing belts!!!!
ok, i just got a 99 z and it had a loud squeal, i thought it was the belt, replaced it and it went away, but i drove about 5 miles and it jumped off, so i thought i didnt put it on right, put it back on, and it jumped off again. everything looks to be inline, but it kinda looks like my crank pulley (harmonic balancer) it wobbling just a little, could that be the prob. or is it ok for them to wobble a little, it feels tight. oh the old belt stays on but squeals really loud!!
PLEASE HELP!!!!!!
Old 06-18-2006 | 02:09 AM
RPM WS6's Avatar
LS1Tech Administrator
All the LS1 car's I've had have a slight wobble to the crank pulley. Don't think that's the issue.
I was going to say that the tensioner is probably bad and causing the belt to slip off but you say that the old belt stays on fine. So I'm thinking that maybe the car has some aftermarket pullies and needs a shorter belt than the new one you just bought??? Just a thought.
Old 06-18-2006 | 02:10 AM
98hardtopZ's Avatar
hows your belt tensioner looking...those are common problems. if you cant find it, crank your car with the hood poped, take a long solid metal object and place it on certain parts of the serpentine system and whatever is noticable louder than the others is usually your culprit..
Old 06-19-2006 | 10:45 AM
REDWS6ROCKET's Avatar
every had the p/s pump pulley off, if so make sure its on all the way, other than that make sure you have the correct belt and a good tesioner
Old 06-19-2006 | 10:48 AM
trouse40's Avatar
the tensioner feel tight, hard to move, but the ps pulley did have a little slack in it!
Old 06-19-2006 | 06:56 PM
JGKadell's Avatar
I had that problem and it ended up being my ASp pulley coming apart.
