Found an ONLINE STORE that sells GC 0W-30!!
#121
ok after doing my research i found that mobil one is alot better for your car then this GERMAN GC oil...i took my car to the track and ran it after a few runs my lifters started making alot of noise, they were getting sticky ..this was with the GC oil!!!! i found that the german oil GC has 11.9 NOACK value, when mobil 1 has 9.3 NOACK value!! do not be fooled by the german GC! noack means burning at high temps and becoming gumpy ect....good luck i will no longer be using GC!!!!!!!!!!
however ams oil has a noack value of 5.4 witch is the absolute best you be the judge
PS i have a turbo car so my car burns really hoT!!
#122
Tech Resident
#124
ChocoTaco369, I've been reading your posts for a while and you seem to make more logical sense than most others. So, this weekend I decided to change out the 0w40 Mobil 1 to GC 0w30. I understand that it is suppose to be protecting better, but the lifter ticking noise is WAAAAY louder now. In fact, even after the car is up to temperature you can still hear the tapping sounds...especially when the engine is revved up and the RPMs settle back to throttle.
I may be overreacting, but I am little concerned that there is so much more clatter now.
#125
Tech Resident
#127
who sells mobil 5w40 in south jersey?
Originally Posted by ChocoTaco369
my engine clatters a little bit, also. it's pretty loud at startup. i INTEND to send this batch of oil out to be analyzed to see my results with the GC 0W-30. after that, i intend to give mobil 1 5W-40 a shot just to see how it compares in an analysis with the same mileage. i've never gotten my GC 0W-30 tested, i've only read others and i base my information off of testing history, but if i can find something better, i'll dump the GC in a heartbeat. my advice to you is to get it tested. there's a company called "blackstone" that analyzes oil that some board members recommend. they send you a FREE test kit and you send them i believe 4 oz of your oil and a check for $20. i intend to get my GC 0W-30 analyzed after 4,000 miles, then get mobil 1 5W-40 analyzed over 4,000 miles. i will run the better of the two. too bad both are a PITA to find. i'm going away to college next week, so getting these test results will probably take me into next year. i urge you to try the tests on your own. no engine is 100% the same, afterall.
#128
Tech Resident
the only other place i've looked is wal mart and they didn't have it. i didn't check advance or autozone.
#129
i found some at my local napa. $5.99/quart. ouch
#130
Tech Resident
that's the same price as GC 0w30 near me.
