Sponsored by: CARiD
Failed CA Smog!!! Help please
Old Jul 12, 2006 | 02:25 PM
2000taws6's Avatar
Default Failed CA Smog!!! Help please
I have the mods in my sig. so I knew I had to put all the stock stuff back on since I couldn't find anyone to help me out with smog. So it takes me two days to rip everything apart and put it back together and pay someone to weld the stock catback up again! The car is already past due on smog and I finally got some time off to get it smoged today and guess what it failed. It passed everything except the NO (PPM) part of the test where ave is 57 and 50/max is 414 and 701/ and I tested 719 and 657 so I failed at 15mph but passed at 25mph. I am so upset I took so much time and money putting this thing back together and it still failed. The car only has 45000 miles on it and the stock exhaust only has 30-35K on it. I passed every other test with flying colors and I am throwing no codes although the rear O2's and EGR codes are turned off due to the long tubes that I had. Can anyone help me out as to what the proplem could be sorry for the long post but this just happened and Im still upset.
Old Jul 13, 2006 | 02:21 AM
SeVeReDiStOrTiOn's Avatar
Did they notice the e.g.r. was gone or did you put it back in also? The cats could be bad...did you try forcing a relearn on the fuel trims when you put the manifolds back on?
I'm in CA also so I gotta ask...is it worth it to pull the LT's every 2 years?
Old Jul 13, 2006 | 11:02 AM
Topless TA's Avatar
Check out the SeaFoam Sticky posted above. It did wonders on my car.
Good luck man
Old Jul 13, 2006 | 11:24 AM
2000taws6's Avatar
I put the EGR back on and I don't have tunning abilities so I can't really mess wth the computer.
I think it is worth having LT's but right now it is becoming more of a hassle than anything. There is no better sound for these cars than LT's with true duals plus the extra 30HP is nice too.
Old Jul 13, 2006 | 11:57 AM
2000taws6's Avatar
Good luck man
I think that I will definately give that a try thanks.
Old Jul 13, 2006 | 12:41 PM
Topless TA's Avatar
NP, oh before i forget I would put 50-100 miles on her before you go back to completely clear the system out.
Old Jul 13, 2006 | 12:48 PM
jattgunman's Avatar
howd you pass the visual? i thought just having lt's was a no no
Old Jul 13, 2006 | 02:20 PM
2000taws6's Avatar
I put the exhaust system completly back to stock and I still failed.
Old Jul 13, 2006 | 02:26 PM
IRACE2's Avatar
You must have a small vacuum leak somewhere. Does it idle correctly?
Old Jul 13, 2006 | 02:34 PM
SexyAssFormula's Avatar
I love florida with no emmisions tests, hopefully that seafoam will help you out
Old Jul 13, 2006 | 02:46 PM
00'WS6Rocket's Avatar
check the cars' timing that will raise the nox
Old Jul 13, 2006 | 07:26 PM
2000taws6's Avatar
Thanks guys. I think it might be because the EGR system is turned off via tunning and causing the NO levels to rise.
Old Jul 13, 2006 | 07:41 PM
Black1997T/A's Avatar
You should have said You had the EGR tuned out. The only purpose of the EGR system is to reduce NOx. If Your smog tech was cool, he could use a mighty vac to pull vaccum and manually operate it while testing, mine did.
