Sponsored by: CARiD
Checking Coolant Level - 98 TA
Old Jul 22, 2006 | 10:51 AM
vipermike2002's Avatar
Default Checking Coolant Level - 98 TA
How do you check the coolant level? My radiator is full but I want to check the overflow bottle. Ive seen some LS1 cars have a little dipstick on the overflow cap, mine does not have this.
Old Jul 22, 2006 | 04:22 PM
santino04's Avatar
Get one! Otherwise stick something down there and see where the fluid is at...Or just pour some water in and top it off, wont harm it. Good Luck
Old Jul 22, 2006 | 09:55 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
DO NOT fill the bottle to the top.
Just get a new cap/dipstick assembly from the dealer.
GM part number is 10188034, unless they changed it recently. Should be about $10. No biggie.
Old Jul 22, 2006 | 10:00 PM
oneBADDz's Avatar
Just drive it around till it's hot, then fill up the bottle until you can tell it's about to come into sight. The level will go down when it cool off and it will come back up when it heats up.
Old Jul 22, 2006 | 10:21 PM
santino04's Avatar
filling to the top doesnt harm anything its friggin coolant, its an overflow tank....big whoop!
Old Jul 22, 2006 | 11:49 PM
RPM WS6's Avatar
If you fill the bottle to the top when the motor is cool, you will be overfilling the system and coolant will eject from the bottle when the motor hits operating temp.
Anyway, the correct fix costs about $10 and takes all of 30 seconds. There is NO reason not to fix it right....
Old Jul 22, 2006 | 11:52 PM
oneBADDz's Avatar
yes sir, that's why I said to drive it around first, and then still not top it off
Old Jul 25, 2006 | 01:21 PM
SailorZ28's Avatar
My coolant level light started coming on 2 weeks ago, off and on. Now the light is on all the time. The temp gauge has recently been running a little higher than the middle, and I'm not sure if it's due to the hot weather or something else. I checked the overflow and the level was fine, is there another place to check the coolant level? What else could cause the temp gauge to run higher than normal? It's not boiling over, and I don't smell coolant.
Old Jul 25, 2006 | 04:20 PM
BobbyWS6's Avatar
I replaced my sensor two times till I got smart and just unplugged it! No more stupid wavy red light... I will not hurt anything to unplug the sensor. It is 3" below your radiator cap. electrical tape it up and zip tie it out of the way.
