Sponsored by: CARiD
Leaking Oil !!
Old Jul 23, 2006 | 02:06 PM
MonkeyBoneSS's Avatar
Default Leaking Oil !!
My engine is leaking oil, noticed it the other day! What is the most common spots for oil to leak from on an LS1. I would get under there but between the rain and long hours at work, haven't had a chance. Just hoping you guys could narrow the search down for me. Thanls a lot, Leaky LS1!
Old Jul 23, 2006 | 04:16 PM
staringback05's Avatar
most likely a seal or gasket, check your rear main seal, the oil pan gasket those are two likely spots
Old Jul 23, 2006 | 04:23 PM
Thanks and I appreciate your time. Hope its one of the two.
Old Jul 23, 2006 | 04:28 PM
2001NBMZ28's Avatar
You're going to need to get in there and look - some other places to check are the oil level sensor on the passenger side of the pan, oil pressure sending unit behind the intake, around the oil filter...
Old Jul 23, 2006 | 08:21 PM
Thanks for the others spots!
Old Jul 23, 2006 | 08:39 PM
GIJosh's Avatar
And dont forget the to check the dipstick tube. Had a crack at the bottom on my ol LT1.
