Oil pressure gauge pinned?
First off, any help you can offer is greatly appreciated.
Well I just changed out my rear knock sensor and broke the infamous oil pressure sending unit when taking out the intake. I needed the car up and running for the drive to Gatlinburg tomorrow morning so I tryed to fix it the quick and easy way and JB welded the thing back in place. I started the car and everything runs normal but the oil pressure gauge reads a constant 90psi and never flinches (maxed out). I've heard if the OP sending unit was broken then it would read 0 pressure and not really be a problem other than it wouldnt work. Now that I see mine is maxed out it got me worried. What could be the problem? I'm not worried about the gauge not working for the drive to Gatlinburg, but is everything else still in safe operating condition? I even checked to see if it threw a code, but it passed showing nothing wrong.
You need a new one. When I broke mine, it was pinned all the way to the right too. I had to drive around with it like that for 2 days until I could get a new one. Everything else will be fine.
