Sponsored by: CARiD
Air Bag sensor, Is it a must to replace after deployment?
Old Jul 30, 2006 | 03:54 PM
618HAWK's Avatar
Default Air Bag sensor, Is it a must to replace after deployment?
Have a 2000 Camaro that had some minor front end damage. Which caused Drv-Pass air bags to deploy. Have located new air bags to install. Question, is it a must to replace the "Air bag sensor Sensing and Diagnostic Module-SDM"
I found that stated info, but I have never heard of a Accelermoter that is a one time use. Is there some thing else that is damaged that requires replacement of the SDM. Granted the unit dose a self test when powered up if there was a fault, it would be indicated by the "Air Bag Light"
Has it just become a standard practice to replace it upon a deployment, from a liability and safety issues for the dealers.
The SDM contains a sensing device (Accelerometer) that converts vehicle velocity changes to an electrical signal. The SDM compares this electrical signal to a value stored in memory. When the generated signal exceeds the stored value, the SDM performs additional signal processing and compares the generated signals to values stored in memory. When two of the generated signals exceed the stored values, the SDM will cause current to flow through the inflator modules, deploying the air bags.
Thanks Chris
Old Jul 30, 2006 | 06:31 PM
2002_Z28_Six_Speed's Avatar
I am not a dealership, but I did replace mine even though the it seemed to work with the old computer. I figured I was worth more than the couple hundred although some people on this site disargee.
Old Jul 31, 2006 | 09:20 AM
618HAWK's Avatar
Would like to hear some more.
Someone has to have some input.
Old Jul 31, 2006 | 10:38 AM
EDS01SS's Avatar
according to mitchell-on demand the sensors must be replaced in the area of impact
Old Jul 31, 2006 | 06:47 PM
618HAWK's Avatar
So sense it sit in the center of the car on the tunnel and there was damage to the front of the car. It would be safe to say it would be OK?????
Old Jul 31, 2006 | 06:53 PM
EDS01SS's Avatar
yup thats what im getting out of it....didnt say anything about replacing the module unless it looked damaged.
Old Jul 31, 2006 | 08:04 PM
HeapaShifter's Avatar
The SDM definately has to be replaced if the air bags went off.
Old Jul 31, 2006 | 08:18 PM
618HAWK's Avatar
Any input on why?
Is it a one time use because something with in the unit is used, which requires replacement.????
------------OR----------
This it is a industry standard to be replaced for liability issues.
Old Jul 31, 2006 | 08:28 PM
General Motors Service Information:
After a collision involving inflator module deployment, replace the following components.
-Inflatable restraint IP module
-Inflatable restraint steering wheel module
-Inflatable restraint sensing and diagnostic module (SDM)
Perform additional inspections on the following components.
-Inflatable restraint steering wheel module coil and coil wiring pigtail - Inspect for melting, scorching, or other damage due to excessive heat.
-Mounting points and mounting hardware for the inflatable restraint IP module, inflatable restraint steering wheel module, and SDM - Inspect for any damage and repair or replace each component as needed.
Old Jul 31, 2006 | 09:03 PM
I bet it is for liability!
Glad I made the right choice though.
