Sponsored by: CARiD
quick question
Old Jul 31, 2006 | 09:31 AM
wssexorz's Avatar
Default quick question
just installed line lock .... i needed a ground for the switch inside my car and i wanted the switch in the ash tray .... so i took the ash tray light out and cut the wires and used that ground wire. i didn't think this would cause any problems ..... now my gauge lights and my hvac lights do not work at all .... i checked the fuse and didn't show any sign of being blown ...
Old Jul 31, 2006 | 11:38 PM
JEB Garner's Avatar
You just may not have grounded your line lock switch be cutting the ash tray light wire. That wire just might be power wire. You did not have to cut any wires to ground the switch. All you had to do was run the ground wire to some screw or something to the car body for a ground.
Old Aug 1, 2006 | 08:30 AM
wssexorz's Avatar
yeah i know but i couldn't find anything to ground it to .... so i just figured i never use this light anyway so cut it .... black or white which one is usually ground for electrical?
