Sponsored by: CARiD
Moisture in parking light lense
Old Aug 1, 2006 | 10:57 PM
Blackhawk777's Avatar
Default Moisture in parking light lense
On my passenger side taillight, I have moisture buildup in my parking light/reverse light and I cant' seem to figure out why or how to get it out. any ideas?
Old Aug 2, 2006 | 08:29 AM
staringback05's Avatar
this is common, i have it on mine i just havent had the time to get it out, theres several ways...lol change the bulb, take it apart from the inside of the trunk and use a blow drier, looks like a fish bowl dont it?
Old Aug 2, 2006 | 01:43 PM
Yeah. At least I'm not the only one with that eh?
Old Aug 2, 2006 | 03:29 PM
tripps's Avatar
I had that problem and it ended up being a crack in the entire brake light piece.
Old Aug 2, 2006 | 05:57 PM
joshp14's Avatar
If there is moisture in there then you more than likely have a crack in the housing or a poor seal at the socket. Unfortunatly these are well known for this problem.
Old Aug 2, 2006 | 06:08 PM
well i just took my light housing off today undid the bulbs and let the water out....its not hard theres 5 fly screws that you can undo from the inside trunk area.
Old Aug 7, 2006 | 09:56 PM
Eiyse98ls1's Avatar
should be the same on may Z. what id did was drill 2 holes on the bottom of each turn signal to let mositure and water escape
Eiyse98ls1's Avatar
should be the same on my Z. what id did was drill 2 holes on the bottom of each turn signal to let mositure and water escape
