Possible window motor problem, help please!
My car has power windows, I was out installing a new shifter and I pressed the button to put them up. The passenger side went up just fine but the drivers side window stopped after going up about 3 inches. I took the key out of the ignition and the put it back in to 'start'. Then I pressed the window button again, and again it only went up another few inches. I repeated this until it was up. Is my window motor going bad ? If so, how much do you think it would cost to fix?
