Sponsored by: CARiD
Need help removing interior sail panel
Old Aug 13, 2006 | 05:37 PM
B.W.'s Avatar
Default Need help removing interior sail panel
This is the only int panel I've never removed
I can't seem to get it off, mainly due to the coat hanger part is leaving me clueless. Does it pull off? Screw off? There is a center piece that I can pull out a little but won't come all the way out
Old Aug 13, 2006 | 06:31 PM
Fratsit's Avatar
The piece in the center that you are able to pull out a little is whats holding the hanger in place. I used a small flat head screw driver to remove mine when I did my QA1 shock install.
The center piece is notched and locks into place once installed. Just takes a little patience to get it out.
R/
Frat
Old Aug 14, 2006 | 12:51 PM
irnbru83's Avatar
it's an annoying piece of crap
I can't get mine to sit right after i put it back on
