Sponsored by: CARiD
Old Apr 25, 2016, 07:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Exterior Guides
Print Wikipost
replacing window motor?
Old Dec 16, 2002 | 01:42 PM
OneQuickSS's Avatar
Default Im stuck..Need help on replacing window motor?
I cant figure out how to get it out, please give me links or steps on how to replace a window motor. Thanks
<small>[ December 16, 2002, 01:50 PM: Message edited by: onebadss ]</small>
Old Dec 16, 2002 | 05:33 PM
felton316's Avatar
Default Re: Im stuck..Need help on replacing window motor?
http://home.swbell.net/shoebox/windowmotor.html
This is the way I did mine. It was pretty easy.
Old Dec 17, 2002 | 05:45 PM
1CAMWNDR's Avatar
What about switching over to manual windows? I'd like to do this to my car. Where is the window crank location on the door panel? Would it come right through one of the Monsoon speakers? Anyone know?
Old Oct 7, 2007 | 08:10 PM
SSsquared's Avatar
Default Thanks
Felton316,
I used the link you provided and had no problems replacing my window motor.
Thanks
Old Oct 9, 2007 | 04:13 AM
discostu's Avatar
this is the way i did it with some help. Removed door panel then the three rivets that hold the motor are behind the door so i used my finger to get a location of the rivets then used a dremel to drill through the door. Then drilled through the rivets. The motor came out with some wiggle work the new motor came with bolts and nuts and with the holes i just made lined up great not to mention it will be easier to change out the motor if it goes out again
Old Oct 9, 2007 | 09:23 AM
VIP1's Avatar
Copy & Paste Moderator
I know this is an old post, but here goes.
There is a sticky on this:
https://ls1tech.com/forums/showpost....1&postcount=18
(That is located in the FAQ in the Stereo & Electronics section)
Here is an updated link to that window motor install so you don't have to deal with a redirect:
http://shbox.com/page/windowmotor.html
(That link is in the Sticky.)
Old Aug 20, 2010 | 10:05 AM
jaysan's Avatar
My situation is different . When I roll my window down it will roll down and make a klunking noise and continue even after it is all the way down . It won't stop to roll down even after I have released my finger off the down button. Any thoughts
Old Aug 20, 2010 | 01:10 PM
wssix99's Avatar
Save the manuals!
Either your rivets/bolts are loose that attach the motor to the regulator or you have a stripped gear between the two. The clunking is the gears not meshing. The motor will run until it runs in to real resistance at the gear.
Old Aug 20, 2010 | 01:13 PM
wssix99's Avatar
Save the manuals!
Take the door speaker out and then that will be easy!
Old Aug 20, 2010 | 08:49 PM
jaysan's Avatar
I checked the rivets and they are tight . So I am guessing I stripped the gear between them . So how do I fix this ?
Old Aug 21, 2010 | 08:04 AM
wssix99's Avatar
Save the manuals!
Take things apart, shoot some pictures, and start up a new thread.
Old Jul 16, 2012 | 08:53 AM
blackfang's Avatar
Looks like I am about to tackle this same job as my drivers side window exhibits the same symptom
Old Jul 16, 2012 | 10:28 AM
blk97z28's Avatar
I used the provided step by step procedure. If your gear is stripped on the motor just replace it. If the gear is stripped on the half wheel that it runs it then you need to replace that...I would do a new motor replacement at the same time..if free to PM me and I'll help the best I can. I've done driver side n passenger side window motor 4 times each, two on my car and then 1 and 1 on friends cars.
Old Jul 16, 2012 | 05:25 PM
blackfang's Avatar
Thanks for the info. If I run into any issues, I will pm ya.
Old Jul 16, 2012 | 11:22 PM
Zlow28's Avatar
its pretty simple to do. My only problem was that i broke the door panel part where the window swith goes.
Old Jul 17, 2012 | 06:14 AM
wssix99's Avatar
Save the manuals!
This part? https://ls1tech.com/forums/general-m...im-repair.html
