Sponsored by: CARiD
No reverse lights
Old Aug 30, 2006 | 10:48 PM
93BlackZ28's Avatar
Default No reverse lights
When i bought the car they worked and all the sudden i notice they dont. So i check them and put a new one in it and they still dont work. When i pulled the bulbs out there was this green stuff that looked like grease, and there was a ton of it, but i dont know what the problem is. Any suggestions?
Old Aug 30, 2006 | 10:52 PM
savethelinoleum's Avatar
i think they call that dielectric grease.. whatever it's called it's supposed to be there. extends the life of the bulb. Are you sure that your other lights are still working? Check the fuse for starters... since you have a manual there should be a reverse light sensor connected to the transmission...?
Old Aug 31, 2006 | 08:14 AM
bygblok's Avatar
it's probably the switch on the trans. My brother's 93 6 speeder has eaten several switches over the last few years. Never had a bulb go bad in his and yes, that "green/yellow" goo is a grease put in to combat corrosion in the sockets.
Old Aug 31, 2006 | 04:20 PM
93BlackZ28's Avatar
where exactly is the switch located on the trans and is it cheap and easy to get?
