need to replace window motor, but mine is rolled down
would that be a problem when changing the motor out?
Quoting from another thread:
"http://www.shbox.com/page/windowmotor.html
It ROCKS, and I'd like to add 2 things.
First, when you drill out the rivets from your stock unit, use a 1/8" bit, not 7/32". 1/8" is perfect for one drill through. Also, his advice of using a 1/2" bit is good if you can't accurately estimate where your rivets are behind your inner door. I used a 1/4" bit and had to widen the hole a little, so in retrospect a 1/2" bit would have been perfect.
Also, you don't need a C-clamp because this worked perfectly:
20oz coke bottle fits so perfectly in there that you don't need anything else to hoist the window up under the pad."
The 20oz coke bottle trick was awesome!
