Sponsored by: CARiD
Maybe valve seals?
Old Sep 12, 2006 | 10:39 PM
Abidar's Avatar
Default Maybe valve seals?
Okay guys,
I've searched and searched and wanted to ask what you all thought about this:
My car smokes white-bluish on startup probably 75% of the time. When at low RPMs, the car sounds like it's ticking. And worst of all, I used to get about 25-30 mpg and now I'm getting 15 to 20. Could it be the valve seals? I've recently done plugs, fuel filter, and pcv valve.
Any ideas?
Thanks
Old Sep 13, 2006 | 01:24 PM
Abidar's Avatar
Check that, I'm now getting 10 mpg as of today...
Old Sep 13, 2006 | 06:45 PM
CASHss99's Avatar
same here, ill get sum smoke that smells rotten at WOT and or start up it burns my nose
Old Sep 14, 2006 | 01:59 AM
1sick'98WS6's Avatar
Valve seals would explain blue smoke on startup
Old Sep 14, 2006 | 02:00 AM
As for the shitty gas mileage and the ticking, pull the valvecovers and make sure you dont have a bad pusrod, and possibly your valves arent seating on the heads correctly making a tight seal..
Old Sep 14, 2006 | 01:28 PM
Abidar's Avatar
Also, whenever I take a hard right turn, just a little smoke comes out the tail pipes.
Maybe the valves on the left are screwed???
Old Sep 16, 2006 | 03:17 PM
Abidar's Avatar
ttt...
