WS6 Store now sells castrol 0w-30!!!!
If ya havent heard, i was browsing around and yes its true! ws6store.com sells it starting monday the 25 of september!!!! 39.99 a case!!!
There are overlaps in the acceptable viscosity levels for each standard. Just so happens that the German Castrol 0-30 is thicker at low temperatures than Mobil Syn 10-30. That is, the mobil is on the low side (thin) of the 10-30 spec, while the Castrol is on the high side of the 0-30 spec.
It is my opinion that both oils are perfectly acceptable, but I do believe the German Castrol to be a higher grade oil. If it is available to you, then it's pretty good advice to use it instead of Mobil synth.
Some people also recommend running a thicker oil should you live in a very hot area like Arizona or what have you, others also recommend running an extra quart.
So, as you see there are many opinions. In the end I think Mobil synth is just fine, but run the German Castrol if you can get it. I would recommend this until such time that either product changes - there are occasional reformulations that may make a difference.
As it stands right now the German Castrol clearly aligns with a couple BMW and Porsche specifications that the Mobil product either doesn't - or they just didn't bother to certify against. If those designations change in the future that's when I'd look back into it.
Originally Posted by 1BADB1RD
just wondering why do you guys use this 0-30 instead of 5-30 or 10-30. i have an 96 lt1 and i use full synthetic 10-30 mobil 1. Is it better to use the 0-30
