Sponsored by: CARiD
Shaking Problem
Old Sep 17, 2006 | 12:40 PM
MarkSTL's Avatar
Default Shaking Problem
I own a 2001 Trans Am and recently under braking my car would shake. I changed the rotors to drilled and slotted, brake pads are replaced and my tires are all spin balanced. A couple of weeks later my steering wheel got a little shakey between 65 and 75 mphs. If anybody would know what the problem is I would appreciate a reply. Thank you.
Old Sep 17, 2006 | 01:24 PM
Mr David's Avatar
probably time to get the front end aligned. I have had to do it once a year. Had my car 3 years now
Old Sep 17, 2006 | 09:59 PM
JEB Garner's Avatar
You know that a balance weight could have come off one of your wheels.
Old Sep 18, 2006 | 09:55 AM
bigman's Avatar
Could be a weight or alignment issue. I have had wheels/tires balanced to a perfect 0, then a week later i would get a vibration only to see that the balancing was off a little. Also and tire out of round can make balanicng a problem. One of the new balancing machines that puts load on the tires can tell if the wheel/tire is out of round.
Old Sep 19, 2006 | 07:04 PM
MarkSTL's Avatar
Thanks for the input.
