Alternator/Ground Strap/dead battery question...
Now...I dont have my voltmeter in the dash hooked up yet...so I dont know if it was charging or not. My question is about the ground strap that is on the driver's side of the engine. Does anyone know if I dont have that hooked up...will the alt still charge? its not hooked up right now. I plan to find/make a spot for it this afternoon. I was just curious if that would cause teh alt to not charge the battery. I have the alt plugged in with the 1-wire plug. And the battery wire is attached to it. So the only thing left is that ground strap.
Any ideas??? Im also getting the battery charged and tested today to make sure its in good shape. Thanks!
justin
J.
I pulled the connector off the back of the alt. and measured for voltage with the engine off and with the engine running. But I didnt get any reading. Im supposed to have 12v there right???
Ok...so now Im stuck. That red wire comes right from the PCM doesnt it? Or does it go somewhere else first? About the only thing I can think to do is do a continuity check on the wire to see if its broken somewhere.. which I hope it isnt after I finally had my wiring routed nicely.
Anyone have anymore input??? Please???
Justin
So I took the plug apart, "un-crimped" the little insert, soldered on a new wire, soldered and heat shrinked it back together. I gave it alittle extra wire too so it wasnt so tight.
And viola!! 14.5 volts at the gauge...and at the battery. All is well!
Thanks!
Justin
